Question about CADAC Safari Chef Portable Grill
Cadac safari grill temp will not adjust. Its either on full or off
5 Suggested Answers
SOURCE: cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Posted on Jun 15, 2008
  • 4736 Answers
SOURCE: The Safari Chef Grill by
You can purchase one directly from the manufacturer at
http://www.cadacsafarichef.com/
Posted on Feb 02, 2011
  • 4736 Answers
SOURCE: can i convert my cadac
Vinnie, first lets take a look at what HP gas is, as opposed to regular LP Gas.
HP Gas is a Propane / Butane mixture liquefied under normal ambient temperature and moderate pressures. It is a safe, clean burning, reliable, high calrofic value fuel. In addition to it use as a domestic fuel, it is also widely used in industries, where there is a requirement of low sulphur content fuel and fine temperature controls. HP Gas conforms to IS:4576-1999 specifications.
Converting your grill to HP Gas may be possible, but there would need to be some adjustments to the burner's venturi valve. As the air to gas mixture may be different. Also, you would need to check with your HP Gas Provider, to see if a different pressure regulator would be necessary.
Hope this helps you and Happy Grilling!!.
Posted on Jun 27, 2011
SOURCE: cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Posted on Sep 30, 2011
My cadac is burning black smoke
Check the venturi tube just behind the control knob and before the burner tube. You will probably find it full of spiders nests. You need to introduce air to the gas and that is where it is regulated.
Jun 04, 2016 | CADAC Safari Chef 6531 Grill
Can i convert my cadac safari chef from hp to lp
Jun 27, 2011 | CADAC Safari Chef Portable Grill
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
Using a cadac burner with a skottel model extension 8304 , with no 24 Jet ( using a LPG 9kg gas Bottle - no Regulator ) flame is good on full ( good Blue Colour ) however on Low Flame keeps going out...
My experience shows me the old steam engine problems.
No gastight connections where they should be.
So not the specified Kilowatts output.
Think of the old fashioned flanges witht the artificial (synthetic) rubber gasket between them. And the flangebolts which held them together, all with the same torque momentum in kilopounds/meter.
Check with good quality leak detection foam and/or use your imagination.
Alternative: look for YouTube High Definition
video 'The Cadac Legend', as of August 15, 2011.
Dutch: ................... Trek in BBQ.
English: ................. Draught in BBQ.
Talkin' about airtight/gastight connections.
Oct 08, 2010 | CADAC Safari Chef Portable Grill
How do i clean the grill normal scourers does not get it clean
Go to the hardware and get a good stiff wire brush. That will get you cleaned up.
heatman101
Aug 19, 2010 | CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
Cadac safari chef
Hi Paul
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
CADAC Safari Chef Portable Grill Logo
41 people viewed this question
Top CADAC Grilling Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a CADAC Grilling Expert? Answer questions, earn points and help others
