Question about Garden
Starts toro 580d wont stay running - Garden
2 Suggested Answers
  • 2926 Answers
SOURCE: Toro lawn mower starts but
The engine is starving for fuel. At this point I am assuming the spark plug is clean and not fouled, and the air intake cleaner is not clogged. The idle jet passage most likely has a blockage, preventing fuel from reaching the combustion chamber. Priming the engine while it is trying to run is forcing fuel to the engine instead of the fuel vaporizing and flowing to the engine.
Posted on Oct 14, 2010
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
I have a toro personal pace that wont start ?
Remove the air box cover and air filter. Spray a shot of carb cleaner into the throat of the carb. Try to start. If it hits and runs for a second then you have a fuel problem, ie. water in fuel, clogged jet in carb, etc. If it wont try and run then its likely another issue, either in ignition or compression.
Oct 07, 2012 | Toro Lawn Mower With Toro Power Tools
2009 31cc toro weed eater wont stay running. will fire and run at idle but wont stay running in 1,2,3 settings
get a can of starter fluid and a helper. Start the weed eater and then squirt enough starter fluid into the air intake to keep it running while you move it through the settings. This will rid your tool of the crud that is causing your problem. Joe
May 07, 2010 | Garden
Wont stay running
Bad fuel or check for water in your fuel! Clean your carb and float bowl. Empty gas into a clear container, if there is two levels of liquid one of them is water. Of course make sure you have good spark plug.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
10 yr old mower, has not been started for 3 or 4 yrs, won't start
Remove the fuel filter and fuel line and replace then try it, if it still does not stay running you will have to change outthe primer bulb. If you need more innformation let me know. Aslo please rate this as this is a free service and thanks for using Fixya.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Wont stay running
Hello:
Soak and Clean the Carburetor.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
