Question about Belkin Surf N300 Wireless N Router
Frequent VPN connection drop on my wifi - Belkin Surf N300 Wireless N Router
  • Belkin Master
  • 7,733 Answers
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
  • Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
  • You must have an active Internet connection for a VPN connection to work.
  • If your modem is external, make sure that the modem power is turned on.
  • Contact your network administrator to make sure that you have the appropriate connection and domain permissions on the remote access server.
  • This could be a certificate problem. For assistance, contact your network administrator.
  • A VPN connection won't work with an active Winsock proxy client. Contact your network administrator to make sure the Winsock proxy client is not enabled.
  • If you know the IP address (for example: 131.107.10.25) of a website, type that address in the address bar of your web browser and press Enter. If this works, there is probably a Domain Name System (DNS) resolution problem. For assistance, contact your network administrator.
  • If you have special software that's required or installed by your workplace, it could be part of the problem. For assistance, contact your network administrator.
  • If you know the IP address (for example: 131.107.10.25) of your VPN server, type that address for the VPN connection, and then press Enter. If this works, there is probably a DNS resolution problem. For assistance, contact your network administrator.
  • There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you see a message that says "The local computer does not support encryption" and has the error code 741, it's possible that the encryption that your computer uses doesn't match the encryption used by the VPN server. To change the encryption settings so that your computer uses the recommended setting of 3DES, follow these steps:
  1. Open Connect to a Network by clicking the network icon (Frequent VPN connection drop on my wifi - eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or ) in the notification area.
  2. Right-click the VPN connection, and then click Properties.
  3. Click the Security tab.
  4. Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
  5. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4Frequent VPN connection drop on my wifi - da12251d-1e9a-4032-afae-009876c6c5a3_80.jpgttp://i.fixya.net/uploads/images/da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  6. Click the VPN connection, and then click Connect to try connecting again.
Posted on Apr 22, 2013
How to setup VPN on iPod?
connect to WiFi.
Tap General>Network>VPN>
you can try these settings I've used before:
Add VPN Connection. chose PPTP.
Give it a name under description.
Encryption Level:Auto
Send all traffic: ON
Proxy: Off
RSA SecurID: OFF
Here's the part that differs from the VPN I personally set up.
Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want.
Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use.
The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
Jan 21, 2015 | Apple iPod Audio Players & Recorders
No wifi
"Problem with Cradlepoint CBR450 Compact Broadband Router without WiFI"
it does not support WIFI will need to get one that does support WIFI to connect that way.
Feb 03, 2014 | Cradlepoint CBR450 Compact Broadband...
My DIR-625 wireless router cannot establish a VPN connection for my new job, using WEP (required). The work laptop CAN use VPN at another WiFi location, like a coffee shop. Suggestions? The DIR-625...
You will need to talk to the IT lead at your job to see if he has given you proper allowances to access the VPN server.
You also may want to check the errors or prompts screens that the the PC is giving this will tell you what the next step is.
Please provide more information as to you issue your issue is not complete as to what you are experiencing for your VPN connection.
2. check the VPN configuration in your PC also there may be a firewall issue here that is not allowing you to connect.
Aug 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
My employer gave me a Dell 6400 Latitude Laptop to use at home through a VPN connection. I have a plug in connection at home. How do I hook up my laptop at home?
Connect your ethernet cable from your Broadband modem into your laptop. Make sure you can browse webpages. Open the VPN software installed by your employer, and enter your login credentials assigned by your employer to authenicate. Once connected, you will have Network Access and Intranet Connections to your workplace. This will work from WiFi hotspots, hotels, Internet cafes, etc. If you do not yet have your VPN software installed, or have your credentials, speak to your employer as they may need to create and account and a certificate for your VPN connection.
Nov 10, 2009 | Dell Inspiron 6400 Notebook
Edimax BR-6574n wifi VPN connection problem
I have reseted the router configuration back to Factory Default, and set it up again from the beginning. I think the problem was at the firewall settings.
Aug 24, 2009 | Edimax PRI-682 Router (PRI682)
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Exceed not working on office network
Well, first, what is your internet connection bandwidth?
Most of the vpns drop the connections when the speed is not good enough, and that means your application won't work fine.
Also, when you use WiFi you can transmit upto 54megabits per second only (the wired network speed is 100MBPS), unless you have wifi N.
Anyway, first I would check the internet speed/bandwidth, test with a faster one, and if everything goes fine, then you know what the problem was :D.
Mar 05, 2009 | Hummingbird Exceed 10.0
Belkin Surf N300 Wireless N Router Logo
165 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
