Question about Garden
Starts wont stay running - Garden
  • 7,482 Answers
Hi michael
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
My 1999 audi car i start it and it and it wont stay running it konks out
Vacuum or incorrect air fuel ratio .also if you moved the butterfly inside the throttle body you will need a throttle position sensor .
I’m happy to assist further over the phone at https://www.6ya.com/expert/joseph_cfbe9ad29efdc8bb
Sep 27, 2014 | Cars & Trucks
95 explorer wont stay running
Someone will need to check the key switch and figure out what is not getting power. Could be the key switch or a relay.
Jun 08, 2013 | Cars & Trucks
1990 Ford F150 wont stay running, replce ECT and ICM ... still wont run. Water coming out of exhaust after trying to run. 5.0 w/5-speed.
Very possible bad head gasket and fowled out plugs and/or O2 sensors. Remove spark plugs and check condition of them and pull O2 sensor to see if it is green from antifreeze. Good luck.
Feb 13, 2011 | 1990 Ford F150
I have a 1992 ford probe 2.2 that wont stay running
try a compression test on the cylnders, If it overheated when the head blew , the rings can go soft with too much heat
Apr 24, 2010 | 1996 Ford Probe
The car wont stay running when in the run possion
OK lets start with this..
I am guessing that when you say possion you are meaning you gear selector and when you put it in say drive.
If that is the case.....
Your problem is most likely the fuel pump relay or fuel pump itself.
Start with checking, or have it checked, the fuel pressure at the fuel rail.
If the pressure is low then a fuel pump can be suspect. There are then other test which have to be performed to see where the exact problem is.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Sep 16, 2009 | 1986 Ford Tempo
Car wont stay running after initial start up?
Will it stay running if you keep the pedal depressed. If so you have a Idle Air Control valve issue. If it wont run at all it may be a bad fuel pump
Jul 14, 2009 | 1991 Chrysler Imperial
I have a 1988 GMC Sierra 1500 thast wont stay running
Use a gage and check proper fuel pressure. With tbi fuel injection, the fuel pressure is 9--13 psi. I have seen fuel injector spray pattern that looked good to me, but, the fuel pressure was half of what it should have been. 5 psi may show a good spray pattern, but, it won't start and run a v8. In my opinion.
Any applicable trouble codes? Your obd1, you should be able to check some codes yourself, if there are any.
Apr 21, 2017 | 1988 GMC C1500
Wont start
if i drive my bronco to work shut it off it wont start sounds like it has a dead battery if i let it sit for an hour it will start back up can you tell me if you know what it is
Dec 15, 2008 | 1989 Ford Bronco
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
