Question about Panasonic Lumix DMC-FZ18 Digital Camera
DMC-FZ18 doesn't hold charge
My camera has recently stopped working. I would charge the battery and within minutes the battery would be drained. I thought the battery would be faulty so I bought a new one but the same problem occurred. Any suggestions what this could be?
Hi! we bought two brand new battery's on eBay for less then $10bucks + free shipping! might want to poke around eBay?
Posted on Aug 26, 2013
SOURCE: error message
*&%$@#%^&*&^% !!"It's working!!!! Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this. Do it under your own responsability. (any way your camera does not work). When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out. With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
Posted on Aug 05, 2007
SOURCE: hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Posted on Mar 30, 2008
  • 16 Answers
SOURCE: panasonic lumix dmc fz18 won't zoom in or out
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
Posted on Sep 05, 2009
BillB-SA
  • 2761 Answers
SOURCE: my panasonic lumix dmc-fx3 camera does not turn
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Oct 21, 2009
cjg20252005
  • 10 Answers
SOURCE: panasonic lumix dmc -fx07 wont turn on...bought a
then chances are something inside the camera is shot, will have to replace it.
Posted on Jan 05, 2010
Panasonic Lumix DMC-FZ18 Digital Camera buttons are not working. Just I can able to switch on & off the camera but no other action
If the problem persists, after removing and reinserting the battery, please use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 02, 2014 | Panasonic Lumix DMC-FZ18 Digital Camera
My lens won't close on a lumix DMC-TZ5
Here are troubleshooting steps for that issue:
Dec 14, 2012 | Panasonic Lumix DMC-TZ50 Digital Camera
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
Recharging battery camera-computer
The camera doesn't charge batteries. Connecting the camera to a computer merely drains the batteries faster, as it must expend juice to communicate with the computer (even if only to say it has nothing to say). You need to use the supplied battery charger or a compatible.
Apr 21, 2011 | Panasonic Lumix DMC-FX01 Digital Camera
Lumix DMC-FZ18 wont power on
Leaving it in the on mode has totally depleted the battery, you say repeated charges fail. Usually leaving it on charge for overnight should revitalise it, if this is not so then the battery should be replaced as attempting to recharge it may cause it to split and spill nasty stuff onto things.
Dont take the risk with batteries in expensive cameras they are cheaper to replace than the camera itself. I remove the batteries from my camera at the end of any session and store them in a tupperware container in my camera gear. That way if they develop a problem it wont affect the camera. It also saves them from running down when the camera switch is left on.
Please rate my help++++Thanks for using FIXYA
Nov 23, 2009 | Nikon D300 Body Only Digital Camera
I can't download photos from my Panasonic Lumix DMC-FZ18
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 31, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
Panasonic lumix dmc fz18 won't zoom in or out after being dropped from a table. the camera can still take photos but not zoom on playback or while taking photos
Sep 05, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
Software for lumix fz18
I just found that I have taken pictures with my DMC-FZ18 without the disk in. It says I have several picture on the cameras hard drive. How do I download these to my computer. Help!!!!!!
Jun 23, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
FZ18 wont turn on
Has it frozen up from a previous use? or won't start up from a completed shut down? If the lens has retracted at the last shut down, it could be the PCB board. Panasonic has been having problems with them, and they are worth 2/3 what the original camera costs + labour!. Call Panasonic directly on it, but have your receipt ready!
Dwight
Aug 04, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Dmc fz18
how can i download the software for this camera on the net...dmc fz18 is a good camera
Aug 01, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Panasonic Lumix DMC-FZ18 Digital Camera Logo
148 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
