Question about John Deere Garden
Fuel filter replacement on john deere JS20 - John Deere Garden
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
Posted on May 04, 2009
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
SOURCE: John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Posted on Apr 15, 2011
Replaced fuel filter on my John Deere LA120 and now it smokes and will not go to full throttle any ideas on how to fix the problem?
you got dirt in your carb when you changed fuel filter you always have to clean fuel filter before you replace it have to rebuild carb now no choice rebuild it
Sep 09, 2014 | John Deere Garden
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
John Deere will not start. fuel filter dry
some models have a fuel pump some are grivitey
May 03, 2012 | John Deere Garden
How to prime a john deere 6415 after replacing fuel filters
disconnect the fuel lines after the filter and crank it. then hook the lines back up and crank it over. if its a diesel use some starting fluid and spray it into the intake to prime it.
Jul 12, 2011 | John Deere Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
I own a John Deere JS20 self-propelled mower. I was mowing my backyard and hit my barbecue grill with the front of the mower. The mower speed (rpm's) dropped dramatically. I checked to see if the...
I had the same symptoms, after bumping the corner of my house - slow drive speed, actually slow rotation of engine. Tried cleaning air filter, replacing drive belt, spark plug; no difference. Took to JD today figuring it was the carb. They went to a piece of the linkage under the shroud ahead of the air filter; a piece must have been bent. I did not see closely enough to know exactly what, but perhaps it will be evident upon inspection.
Aug 11, 2010 | John Deere Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Jim Kite paris, il
Apr 18, 2009 | John Deere Garden
Garden Logo
147 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
