Question about RCA Universal Remote Control
GOT A RCA XL 100 REMOTE XS STEREO TV AND A ONE FOR ALL REMOTECAN GET THE REMOTE TO PROGRAM THE TV NEED TO KNOW THE CODE OR WHAT IM DOING WRONG
    Top Expert:
  • RCA Master
  • 74,106 Answers
273,279,226,236,217,213 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Check this site too.
Posted on Apr 22, 2013
IrishDruid
  • 2712 Answers
SOURCE: having problems programing rca remote
Try these codes for Emerson TV: 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 22, 2008
centralhigh
  • 260 Answers
SOURCE: RCA REMOTE CODE
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Posted on Jun 25, 2008
  • 5 Answers
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: olevia 32 inch tv rca universal remote need a code to program
Try using code 11610
Posted on Feb 15, 2009
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
I have an audiosonic 1201 combo dvd tv and need a code for digitech ar-1719 universal remotecan anybody help
Go online for your product to find the codes. Follow the universal remote instructions to program it for your TV.
Some remotes are easier than others. A list of TV brands should have been included with your remote. You can also go online for the remote and get the codes, too.
Sep 20, 2016 | Televison & Video
Which one of these rca, universal remote controls, would work for my, rca tv model xl 100 xs stereo_ commercial snap???? Any idea? Thanks
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Oct 09, 2015 | RCA Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
Need remote code for an RCA XL100 tv
I just programmed my RCA XL-100 today! The code is 11447
Jun 11, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
Looking for codes for remote
I have a RCA XL 100 tv have tryed to program with this GE remote but didnt work what more can i do or if yor have a code that really work that will be great
May 12, 2010 | RCA Universal Remote Control
I have an rca remote modle rcu730 and i lost the guide and im trying to program my remote to an symphonic tv and i tried to codes that the computer keep 064 076 and neither of them seem to work do you kno...
Programming using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Feb 01, 2010 | RCA Universal Remote Control
Need remote code for rca XL100 XS stereo Tv
The remote code you seek may not be available in every remote; none of them are 'universal.'
You need to go to the website of the remote manufacturer and look for the code list for that specific model of remote.
Oct 17, 2009 | RCA Universal Remote Control
Need code
RCA 0047, 1047, 1147, 1247, 1347,
1447, 1547
one of these codes will work i got the manual link for you
http://www.solidsignal.com/manuals/URC-3021%20Remote.pdf
this should help you scroll to bottom of the pages
May 13, 2008 | One For All URC-3021 Remote Control
Remote control code
i need the code for the rca xs stereo universal remote
Apr 07, 2008 | RCA F27442 27" TV
Televison & Video Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
