Question about Frigidaire FGHD2433KF Builtin Dishwasher
Have Frigidaire Gallery Dishwasher, model FGHD2433KW1, had to relevel machine. Got finished and the hold lock light is lit and will not go off. with this light on, machine will not function. any suggestions?
  • Larry Lunger Apr 21, 2013
    IT is done. no more help needed.
  • 1003 Answers
SOURCE: FDB768GCC0 model Frigidaire Gallery series Dishwasher
REPLACE TIMER
Posted on Jan 18, 2008
SOURCE: frigidaire gallery series FDB125ORES1 wash
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Posted on Sep 03, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
heatman101
  • 43501 Answers
SOURCE: standing water at bottom of dishwasher. Make and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 01, 2010
  • 1531 Answers
SOURCE: I have a Frigidaire Gallery dishwasher model
you need to rpelace the electronic control board
Posted on Oct 23, 2010
Frigidaire gallery washing machine door lock light doesn't come on
normally the door catch on washing machines have a switch attached to it ,if the door is not closed properly then the switch is not operated ,stopping the door lock light coming on
try slamming the door shut or check door catch for damage or hold /push and (hold )door shut to see if lock light comes on, if it does then the problem is door catch, adjustment or replacement only suggestions .good luck
Sep 27, 2016 | Frigidaire Washing Machines
I am trying to locate an owners manual for a Frigidaire Dishwasher model # FGHD2433KW1
Below is the link, you can download it
http://www.manualslib.com/products/Frigidaire-Fghd2433kw1-2885301.html
Dec 05, 2015 | Frigidaire Dishwashers
The green light says hold to lock. does not go out. can help turn off plz
Hi friend, thank you for your post!
I understand that the green light for your lock on your Frigidaire dishwasher is not turning off. I see your question is labeled under the model number GSB5712BC based off the design of that control panel you should be able to hold down the power dry button and the lock light should turn off.
If that does not correct the issue I would perform a reset on your dishwasher. You can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes. I hope this is helpful. -Matt
Sep 29, 2014 | Frigidaire 24 in. GSB5712BC Gallery...
Disherwasher will not start
Are you sure it is the Dry light that is lit, or is it the little Lock symbol located ABOVE the Dry button that is lit? If it's the latter, you can turn off that light (turn off the control lock) by pressing and holding the Dry light for 4 or 5 seconds until that light goes off.
Aug 04, 2014 | Frigidaire Dishwashers
Frigidaire gallery FGHD2433kw1 error washing clean drying ER s ...
The ER error code means the touchpad is defective..sometimes that can be just a loose ribbon cable connection to control board. or if that seems tight the touchpad which is part of the console should be replaced
Aug 23, 2011 | Frigidaire FGHD2433K 24 in Builtin...
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
My Frigidaire dishwasher will not start.
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
Nov 18, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire FGHD2433KF Builtin Dishwasher Logo
117 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
