Question about Zebra Z4M Printer
2 printer on 1 pc
I want to connect 2 zebra printer on 1 pc but i can't
    Problem Solver:
  • 17 Answers
You can use serial port printer1 is on the COM1 printer2 is in the COM2 if you dont know the pin configuration of cable just PM me ill send it to you
Posted on Mar 20, 2009
  • 155 Answers
You can buy a Usb to Centronics adapter that installs the printer as can be LPTx, and have the printers you want.
Posted on Mar 13, 2009
When I try to print multiple cards, only 2 cards print, the same two all the time, the others don't
It sounds like you might have a job stuck in the print-queue. Best way to check is to start with a clean slate:
1. Shut-down your badge-software, and disconnect the printer from its power source;
2. Navigate to the Windows print center - accessible from the Control Panel as "Printers & Faxes" if Windows-XP, or "Devices and Printers" if Windows 7.
3. Right-click on your Zebra P110i printer, and select "See What's Printing" to open the queue, and see if there are jobs there. If so, click "Printer" on the menu, and then "Cancel all Document".
4. You also should ensure that you don't have any additional instances of the printer drive installed - they would show up as Zebra P110i (Copy 1), ... (Copy 2), etc. This occurs within Windows if you've disconnected the PC-end of the USB cord, and then plugged into a different USB port than originally used. If you have multiple instances, the easiest way to clean this up is to right-click on each sequentially, selecting "Remove this Device". Do this for each one.
5. Now you have a "clean slate". Connect the Zebra printer to the PC's USB, and then re-connect the power. If it doesn't power on, push the power button so it is on.
6. WAIT until Windows recognizes the pritner and you see the device is ready to use.
7. Open your badge software, and select a single card to print, and send it to the printer. If all goes well, this single card will print correctly, then the printer will come back to a ready status. Repeat for a second card, and make sure it prints correctly, and comes back to ready. If all is good, you've likely cleared the issues up, and you can proceed normally. If not, then there may be a physical problem with the printer, where it is not recognizing that a finished card has been ejected and the job is done, or it's not communicating that "done" status back to the host PC.
Feb 07, 2015 | Zebra P110i ID Card Printer
Create a label 3, tlp 2844, not printing
it depends what interface its connected to. your manual shows usb/lan/parallel. if i had to guess 1) uninstall printer completely, detach it from computer, follow connection as per original documentation 2) if its lan connected then its IP might have changed, adjust the TCP/IP port values (printer properties configure port) to the IP that the printer prefers. 3) turn it all off, and only plug it back in to the USB port originally used to install it because the usb driver is POOR and cannot SCAN for it being plugged in to a different port. 4) its plugged in to a FRONT USB port on a pc that means its LOW power port, plug it in to a REAR port which is HIGH power. those are my best guesses. I also note the zebra site has a separate setup utility maybe re-running that will re-find the printer. https://www.zebra.com/content/dam/zebra/manuals/en-us/printer/tlp2844-ug-en.pdf
Dec 12, 2017 | Zebra LP 2844 Thermal Printer
Zebra lp2844 just keeps feeding labels
Power off your printer and disconnect it from the PC.
Allowe about 2 minutes for it to clear its buffer and then power it back on without connecting it to the PC.
If the problem still exists,
It may be a faulty paper sensor on the printer
Feb 10, 2011 | Zebra LP 2844 Thermal Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Zebra S300 printer pauses without printing additional copies
I Use driver from Nice Labels
http://www.nicelabel.com/downloads/nicedrivers/zebra seems to work fine
Dec 05, 2008 | Zebra Stripe S300 Thermal Label Printer
Printing mixup
Your problem is a computer configuration issue, not a printer problem.
Without knowing any details of your system configuration, it is impossible to offer and further advice.
Steve W
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
Zebra Z4M Printer Logo
98 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
