Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
There is some problem in starting window media player
When last time I started window media player I read a message appear on the screen regarding some problem is encountered by it and after this it does not respond.Kindly suggest me what to do to fix it.
  • 55 Answers
First try downloading a registry cleaner like "C-Cleaner", "Advanced windows cleaner" or the like and run them, the registry might be colliding with something when you open WMP. Just google them and type free download, they're not very big.
If that doesn't solve the problem, you'll need to re-install WMP, yopu should be able to download it aswell. Just make sure to remove the entire old version of WMP, C-Cleaner has a utility that can do that for you. Hope it helps! Good luck!
Posted on Mar 12, 2009
Only white screen appears while starting.
My Creative Zen 16Gb got to the stage where every time I turned it on I would get a white screen. I tried many so called solutions, including those on the Creative website - nothing really workd for any length of time. Eventually, suspecting is was a connection issue with the dispaly, I held the Zen in both hands and twisted the case a few times - nothing broke and my Zen has been working faultlessy for the last three days. Hope this helps.
Nov 17, 2009 | Audio Players & Recorders
Windows media player error message
Options:
1. Restore your system to an earlier time.
2. Re install media player on control panel add remove programs uncheck and recheck media player on add/remove windows components and click next... then re-start your system.
3. Download your version of Media Player or an upgraded one from Microsoft and install it.
Apr 25, 2009 | Microsoft Windows Media Player
Each time the computer starts the windos multi
Hi there
can u go to the settings of the player and uncheck the start up when windows starts option
Mar 19, 2009 | Computers & Internet
Problem with my samsung PY-P2
How do i get my samsung mp3 touch screen 8 gb to restart and start over
Oct 01, 2008 | Samsung Yepp YP-P2 Digital Media Player
Helppppppp!!!!
There is a problem with the USB cable or your USB ports - check Start--> Control Panel--> Printers and Other Hardware --> system --> Hardware--> device Manager-->USB Controllers for more detials (I am assuming Windows XP) - see if there is a yellow exclamation by your USB port
or
try a different usb port or cable
or read my "tips and tricks" on sansa players
or
Go to sansa's website
You are sure to find some sort of answer
-Tha Mp3 Doctor
May 29, 2008 | SanDisk Sansa e250 MP3 Player
Optiarc cd-rw crx880a ata device: This device cannot start. (Code 10)
Did you try to click "Troubleshoot" on the page that reported "cannot start" ?
Did you try to click on the device, and choose "uninstall" ?
Then, rebooting Windows should cause Windows to "find new hardware", and properly configure the DVD/CD drive.
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
Mixmax froze
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Mar 06, 2008 | Disney Mix Max Digital Media Player
I can't transfer any song
Try using windows media player to transfer the songs or if all else fails, use explorer.
Feb 13, 2008 | Sony Network Walkman NW-A1200 MP3 Player
A problem occured using m y mp3 player
Deleting files through Format:
1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode.
2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process.
3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears.
4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen
5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player
***Or you can use windows media player to format your player....
Open up your windows media player and click on the sync tab..assuming that you have windows media player 11...right click on the device and hit format..if you have windows media player there should be a little pen or pencil on the right side..just click on it and hit format..
I hope this helps. :)
Please rate accordingly...
Jan 26, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Player won't start up
Reset, firmware, recovery - iRiver website
Aug 31, 2006 | iRiver H10 MP3 Player
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
