Question about Coffee Makers & Espresso Machines
Miele cva 5060 water container not pushed in
Keeps saying water container not pushed in even though it is
SOURCE: Miele CVA 5060 descaling is stuck
Did you figure this out? I've got the exact same problem.
Posted on Oct 24, 2009
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
SOURCE: Says in the display Fault 10 and Fault 17. CVA
I just switched machine off for a few hours and when started, it was OK
Posted on Sep 08, 2009
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
SOURCE: Miele coffee system cva 615.
More then likely there is nothing wrong with the water seal but simply the tank was not placed properly over the seal and water was bypassed to the reservoir. If a significant amount of water sits in the reservoir the "Water System Fault" trouble will appear and stop operation. The easiest way to remove the water from the reservoir is with an inexpensive ($5) siphon tool available at any auto parts store. Once the water has been removed and you can operate the machine and it goes through the "Warming" sequence you will receive a "Air in water System" alert. Follow the simple directions in the manual to correct this trouble and your system is back to normal. I have heard people have been charged by technicians up to $600 to fix this trouble and told the seal had to be replaced. Just take care when placing a full water tank back into place and enjoy : )
Posted on Aug 08, 2010
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
Only one spout dispenses coffee
Same for my CVA 5060 : the right spout seems to be blocked...
I tried a cleaning cycle and a descaling one with no success.
Any idea of where to clean ?
Apr 13, 2014 | Miele Coffee System
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
Miele 5065 descale program will not complete
Sounds like you need to get into the programming mode menu and reset it. I have a Miele CVA 4085 built-in coffee maker which had a similar problem to this and other problems where it gets locked into a state where it demands you empty the drip tray even though it is empty. In my case it was at the end of a cleaning cycle and refused to go on. Cutting power and restarting always had it return to the same state: Cleaning, empty drip tray.
I cleaned the contacts on the drip tray and at the back using the nail file, still nothing. Then I found a post on how to get into the programming menu, which on the CVA 4085 is this:
  1. Open the door and switch off the power with the rocker switch on the top left.Wait at least 5 seconds.
  2. Switch the rocker on then VERY QUICKLY close the door and hold the clear button for 5 seconds.
  3. With your other finger touch the ON button then pull both fingers away at the same time.
  4. Do 5 rapid presses of the clear button but hold your finger down on the last press and keep holding it down until the programming menu comes up.
  5. Do not press the reset button that you see at the top of the menu (unless your German is quite good or you have access to Google Translate).
  6. Scroll down until you find the reset cleaning button and select it. Once you have confirmed you can then exit programming mode by powering off.
It took me quite a while to get to this point, but at least I can now recognize the German word for drip tray.
May 22, 2012 | Miele Coffee Makers & Espresso Machines
I need to know the concentration of descaling tablets to water to descale my cva 610 coffee maker. The instruction manuel says to fill the water container HALF WAY with correct solution of descaling agent...
The following web page has the instructions for mixing Jura tablets:
http://www.jura.com/download_information-sheet_jura_descalingtablets.pdf
I tried to find the same info in Miele's manual, but it didn't specify, but is probably the same as Jura:
http://www.cagrimmett.com/justanswer/CVA610.pdf
If you have the box or package that came with the tablets, it should say how many per volume of water. If it doesn't, contact the manufacturer.
Good luck, and hope this helps.
Dec 15, 2010 | Miele CVA610
Sep 05, 2009 | Miele Coffee System
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
133 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
