Question about Simplicity for Children 8994W Crib
What dose the yellow bar mean on matteress tube support frame on model # 8994w
I'm wondering how much a Simplicity crib model #8994W is worth in store credit. I know it has been recalled and would like am estimate before I go to the store.
Simplicity crib 8994W is worth about $150.
And you are correct since the manufacturer is out of business, the stores that sold this crib (mainly Target, Babies R Us and Walmart) are offering store credit.
The word on the street is that Babies R Us is a bit of a hassle to deal with this on this and is giving between $50 and $70 store credit.
Wal-Mart has reportedly been the easiest to deal with and is giving store credit of approximately $190.
Good Luck.
Jan 24, 2011 | Simplicity for Children 8994W Crib
How bike size is measured?
So what does "different frame size" actually mean? And what does that frame size number, 13" or 25" or whatever, mean? It's fairly simple.
The frame size number comes from the length of the seat tube. The seat tube is that nearly vertical tube of the three big tubes that make up the "main triangle" of the bike frame. The seat tube has the bike's saddle attached at the top, and has the pedals and crank arms attached at the bottom. A short seat tube will make the pedals closer to the saddle; a long seat tube will make the pedals further away. The frame size number is the length from the center of the crank arm spindle (the axle that holds the two crank arms together) up to the top of the seat tube (where the saddle and seatpost are attached). On some bikes this is measured in inches, on others in centimeters.
But that's not the only dimension that changes for different frame sizes. As bicycle frames get taller, they also get longer. That means the distance from the saddle to the handlebars gets longer. This makes sense, since tall people don't just have longer legs than short people. They usually also have longer arms, a longer torso, and so on. So the bike frame also needs to get longer in every direction for a taller rider, not just longer from pedal to saddle. The top tube gets longer, which pushes the handlebars further away from the saddle. The head tube (the frame part that the fork attaches to) gets taller, so the handlebars will be higher up. All of these dimensions and more are fine tuned in every frame size, so the right size frame for a person's height fits well everywhere, not just in the saddle.
Dec 21, 2010 | Cycling
How size is measured? So what does “different frame size” actually mean? And what does that frame size number, 13” or 25” or whatever, mean?
Dec 16, 2010 | Cycling
8994W Crib: How do I convert a Simplicity, Inc crib model #899...
There is a recall on thin crib you can take it to the store were you bought it and they should refund your money. I have one and Im taking my to the store tomorrow.
May 17, 2010 | Simplicity for Children 8994W Crib
8994W Crib: is 8994w the same as the recall crib 8994...
Yes, it is the recalled crib. The W is jsut the color code.
May 03, 2010 | Baby Gear
Can i get repair parts for the crib anywhere. model #8994w it has never been used yet
The manufacturer will normally replace these parts for free. The phone number for Simplicity for Children is 1-800-858-8323.
Dec 22, 2009 | Simplicity for Children 8994W Crib
Lost crib instructions please help
It seems that the company may be out of business. I have been searching for instructions for an 8748AWT for a long time and have never found them.
Mar 13, 2009 | Simplicity for Children 8994W Crib
Lost instructions on hoiw to assemble welsh crib
the Welsh "juvenial products for better living" used to be at 1535 south eighth st, st louis, mo 63104
photos are included of the model parts 175 which took a matress no thicker than 6 inches 27 1/4 x 51 5/8
http://s371.photobucket.com/albums/oo152/fallingstarvideo/welsh%20crib%20products%20for%20juvenile/
the hooks are where the matteress goes. if you took off the long L bracket with hooks there are 4 of these. BUT 2 are shorter than the other 2, the short side goes on the drop down crib side. there is a close up on the photos but the silver hooks are where the silver bar hooks on to on the sliding rail to go up and down
Jan 11, 2009 | Baby Trilogy Innovative Corner Crib
Simplicity for Children 8994W Crib Logo
41 people viewed this question
Top Simplicity for Children Baby Gear Experts
Dennis Crouse
Joseph Hoffmann
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
