Question about Ryobi Garden
Ryobi Weed Hornet RWH1100 Mk 11 - carby diagram required.
The above has been out of action for a number of years after the fuel lines bacame brittle and leaked fuel.
The fuel lines have been now been replaced but the carby now floods when the fuel primed bulb is used. The engine will start (after many pulls) but will onlr run for 20 seconds or so.
I suspect the carby needs checking, especially the float valve, and cleaning but I would like to have a carby diagram before I touch it.
Can anyone help with a carby diagram or other suggestion.
Thanks
jim
  • jimmanion200 Apr 07, 2009
    Thank you for the information. I haven't had a chance to check it out yet.
Had similar problems with my mum's 77. she was going to throw it out so i adopted it. turns out i just needed to adjust the injection screw. couldn't tell u where it is as i did it five years ago but armed with the knowledge that carbys have them and a bit of dissassembly i was able to fix it pretty easily. still runnin great now till the starter mechanism stuck. time to pull it apart again, hence my visit to this forum....
Posted on Nov 16, 2012
What is the fuel mix for a Ryobi lawn Hornet Mk 111
Buy a 2-cycle oil of your choice and mix it according to what the oil says to mix it.
You'll be OK.
Sep 16, 2017 | Ryobi Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
I have Ryobi Weed Hornet Model RWH1100A MKIII and the primer bulb has disintegrated. I'm told spare parts are not available as this model is not made any more. Is there any way I can bypass the pr
The primer only pulls fuel from the carb, into the bulb and dumps back to tank, this is a starting aid so there is always fresh fuel in the carb, you can just blank of the pipe from the carb to the primer, this will just turn it into a standaed non primer carb, if it starts ok just useing the hoke then leave that way
Mar 14, 2012 | Garden
Fuel line for ryobi
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers~~~hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ``
Feb 12, 2012 | Garden
Needs carby ajusting for ryobi lawn hornet 70 about 15 years old but has been great
Hi duthie20, the low speed(closest to engine block) should be 1 and a quarter the high speed 1 and a half(the other one). That should get ya going, you may have to tweek these adjustments a little eigther way. Happy New Year!
Dec 28, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
Fuel ratio for Ryobi lawn hornet mk 2
25 to 1 = 200ml of 2st oil to 5 lt ulp
OR I use 150 ml "stihl" 2st oil to 5 litre of ulp Less smoke and better oil.
Jan 12, 2009 | Garden
Garden Logo
1,324 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
