(root) user locked out in mitel pbx , i need to access my pbx what can i do ??
Iam try to login to mitel 3300 by Root and in next day suddenly its not working and i tried many times, unfortunately locked out please if any one have a solution to my big problem please connect me here or in verytory@hotmail.com
SOURCE: Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
Posted on Sep 10, 2008
  • 5 Answers
SOURCE: MYSQL Access denied
Hi Buddy,
Try this option....
mysql -u root -p
mysql will then ask you for the password give the proper password.
For changing mysql root password
mysqladmin -u root -p password <<newpwd>>
then mysql ask you to give password this is the old password and now the new password for the root will be newankush.
Posted on Sep 29, 2008
kleeper
  • 87 Answers
SOURCE: Password recovery
http://www.securecomputing.com/techpubsRC.cfm
Posted on Oct 20, 2008
  • 8 Answers
SOURCE: CDE login is locked out (mitel 200 ml)
You do not need to reboot the PBX but you will have to wait 20-30 minutes before you can re-enter the password. It locks the system for the above amount of time
Posted on Feb 10, 2009
SOURCE: we have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Posted on Jul 10, 2009
I recently bought an unused NASSTOR NAS COPPER storage system, the default login information was not available though. Does anyone know default login that Nasstor use on systems with a Centos OS ?
Odd. During installation you get prompted for both a root password, plus a non-privileged user + password.
So after install you will always have both privileged and non-privileged access.
It is the non-privileged user you should use for logging on to the desktop, and use 'su -' whenever you need root in a terminal.
Graphical ui-tasks that require root will prompt you for the root password.
Still unable to do it, Contact customer Support :- +1(800) 243-0051
Apr 13, 2017 | The Computers & Internet
How do I cancel a programmed key?
What platform is your phone contacted to? Mitel 3300, Mitel 5000, Mitel 2000?
Mar 13, 2015 | Mitel 5330 IP Phone
Root pasword for compaq presario with Linux operating system
Dear cockniegeezer,
Please post more info! Are you able to login at all? i.e.: with a 'User' username/password? If so, try using 'sudo' on the CLI - "command line interface" or "terminal" before required command...this will then ask for your password & allow you to do commands that require "root access". Hope this helps...or at least points you in the right direction! GBU! - Bruce.
Apr 06, 2013 | Computers & Internet
What is the default ip and user name, password for this model ????
The "IP address" is your DEFAULT GATEWAY so you can try 192.168.1.1 or you have to check it by going to START>RUN and type CMD in the box and then Enter (brings you to the COMMAND PROMPT type IPCONFIG and enter you will see your DEFAULT GATEWAY.
For the user name and password (you didnt mention the model #) so for all US ROBOTICS the User names are (unless you changed it) try "root" "Any" "support" "Admin" and Passwords are (unless you changed it) "12345" " Admin" "support" "password". If you did change it and cant remember you can always press the reset button on the back and restore it to the "Out-Of-The-Box" settings.
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Jan 06, 2011 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
When you turn the macbook on it asks for a username and password and i recently changed it and didnt write it down is there anyway of getting passed it
Did you choose a security question? (helps recover password)
OR Try This (taken from another forum)
"Try this
Although there's no real way to recover a lost root password, you can change the root password even if you do not know the current one. You must have physical access to the machine in order to accomplish this task.
Click Restart at the login window
While the computer is restarting, hold down "Command-S" until you see text scrolling through the window.
This boots the computer into single user mode.
At the Localhost% prompt type:
/sbin/mount -uw //sbin/SystemStarter
You will then see various services starting up.
When the Localhost% prompt reappears, type:
passwd root
It will then ask you to type the new root password twice, so do so.
After entering the new password, type:
reboot
At the login window, enter username root wih the new password.
Once you are connected, you can use the Multiple Users application (/Applications/Utilities) to change your normal user's password, or create a new user account."
Apr 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Nov 05, 2008 | Mitel Computers & Internet
Change user
You need to log into the PBX and change the name in the Telephone Directory. You can't do it from the phone
Jul 30, 2008 | Mitel 5220 IP Phone
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
