Question about Siemens Gigaset 4015 Cordless Phone
Hand set and base not cetting connected, searching base display
Mine is a GIga set 4015, bought in Swiss , can i get it repaired properly in india. not able to use due to above trouble. Base and handset stting procedure was followed as per operating manual but in vain. set is new pl. advise.
Handset to baseset registration code
Posted on Oct 16, 2010
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
Problem with the Siemens Gigaset 4015 Cordless Phone Hand set and base not cetting connected, searching base display
There is most likely a problem with the base unit
try resetting it to factory defaults and re-register all of your handsets one at a time
Aug 17, 2011 | Cell Phones
I have a swiss legend swiss quarts movement watch. It will not keep time i set it and the second hand at the bottom will go for a while then stop. i am not sure what is going on. The model number is Swiss...
mcdevito75 here, Possibly the battery is weak, (Need New Battery) or the quartz mechanism is going bad, see the repair service directory here at fixya, bottom of page click on repair service directory then watches.
Jun 24, 2010 | Swiss Legend SL-LUCERNE-ML134AC Wristwatch
Ricoh FT 4015 too dark
Depends how many copies are in it. The PCU goes at about 60,000 prints its ordered as a supply. This is the heart of the machine. Lastly would be the fuser. -Carl
Jul 10, 2009 | Ricoh Office Equipment & Supplies
My superset 4015 mitel corded displays locked
repeat the connection and the unlocked no if you have it better use it
Jun 22, 2009 | Mitel Superset 4015 Corded Phone
The screen on the hand set displays searching
PIN restore Gigaset 4010/4015 base
If the PIN code forgotten your Siemens Gigaset 4010 / 4015 base (Classic / Comfort / Micro) then follow these steps to create the reset:
* Take the power cord out
* Press the button and on the bottom of the base and hold
* Insert the adapter into the outlet, hold the base button
* Wait 30 seconds, keep the button pressed
* Wait 10 more seconds and remove the adpter from the outlet
* Put the adapter back in
The unit is now reset and the PIN code is 0000.
Mar 22, 2009 | Siemens Gigaset 4015 Cordless Phone
Address for Olympus digital camera outlet in mumbai,where I can get my camera repaired
On page below you find the list of authorized repair and distributor in India:
OLYMPUS India Centre List
In Mumbai contact:
Camera Care Centre
225, Commissiriat Bldg. Next to Old Hendloom House, Dr. D.N. Road, Mumbai 400001 India
Digital Camera
Tel :(91) 22-2261 1274 / (91) 22-2261 4015
Fax :(91) 22-2261-0219
E-mail :cameracarecentre@gmail.com
Alternatively:
I.R.Technology Services Pvt. Ltd.
B-8, Commerce Centre , 78, Tardeo Road, Mumbai 400034 India
Industrial Microscopes
Tel :(91) 22-2495-1085
Fax :(91) 22-2495-0584
I will be grateful if you can give proper vote to my solution.
Thanks.
Feb 27, 2009 | Olympus FE-210 Digital Camera
Philips CD130 Cordless Phone User Manual
registering again didn't work for me. I used the following steps
1. close the handset (long-press red button)
2. discconect the base unit from the power source
3. reconnect to the power source and long press the intercom (the only button on the base unit) for 5 seconds.
4. turn on the handset (long-press red button)
with 2 seconds and it will be connected again.
hope this helps.
Jan 25, 2008 | Lands Phones
Answering machine
Unfortunately the 4010 model does not have a built in answering machine but does have features to work with your local telephone companies voice mail. If you want to keep your same phones and get a base with a built in answering machine you will need to replace your 4010 base with a 4015 base (up to three handsets), or a 4215 base (up to four handsets). But don't toss out your old base, you can use it to extend your range if you ever use a 4200 series handset that will allow you to register each handset to up to four seperate bases simultaneously to extend the range. You can buy the 4015 or 4215 base only and save yourself some money. You can google Siemens cordless repair or go to the Siemens website to find a few options.
Aug 12, 2007 | Siemens Gigaset 4010 Cordless Phone
Siemens Gigaset 4015 Cordless Phone Logo
577 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
