Question about Danby Premiere DDR5009REE 50 Pint Capacity Dehumidifier with 2 Fan Speeds, Electronic Controls, Adjustable Humidity Settings, Direct Drain Feature and 3,000 sq. ft. Coverage Area
Compressor Works for a while Only On Initial Plug-in
The compressor stopped working. After some fiddling around, I discovered that the compressor will work only by the following method: 1. Press on/off button to turn off dehumidifier then unplug it from the electrical outlet. 2. Plug the dehumidifier into the electrical outlet, then press the on/off button to turn the machine on. 3. Keep pressing the down arrow to set the relative humidity lower until the compressor comes on. This is the only way I can get the Compressor to come on. If I just press the button to turn the machine off and then on, the compressor never comes on. I tried it for 12 hours and NO WATER and the compressor never came on. Then, when I press the on/off button to turn the machine off, then unplug it, then plug it in again, then press the on/off button to turn it on, then set the humidity until the compressor is activated. However, after these actions, the compressor runs for less than a minute and then it shuts off, and only the fans continues to run. Can someone explain why this is happening and how it can be fixed? Thank you.
  • walt dutchak (wladicus)
    Finally figured out that something like a humidistat is no longer working or is faulty. Problem is that I had no idea where to locate it, what it looks like and no diagrams available for detailed self repair. So I put the machine out on the road and someone came along and cut off the cord. Great idea! I should have thought of that. Since then I have purchased 2 Gree dehumidifiers from Costco (45 pint and a 30 pint). They are quiet - fan and compressor shut off when humidity setting is reached and they have worked beautifully. Great service department also - customer service is in Quebec city, Canada. *** No longer have the Danby problem *** SOLVED ...
  • 420 Answers
If your machine is equipped with a humidistat it could be faulty and not sensing the humidity level accurately.
Posted on Mar 16, 2017
It is very loud and gives an instruction in the form of E1 then it switches off eventually.
Wild guess, the fan is not working as it should. Too slow or perhaps bad instruction from the "brain". I would guess after some time of "cool down" It will turn on again and do the same thing? Not likely, but the filter needs to be changed, or the coil is
very dirty and cannot "dispose" of the heat fast enough so the compressor works harder, gets too hot and It's overheat switch stops the compressor.
Mar 27, 2015 | Dehumidifiers
Why did my dehumidifier suddenly stop dehumidifying, fan works fine
check that the tank isn't full or the outlet hose is not blocked. Remove the filters and clean if required.
Jul 27, 2014 | Fedders A7DH45B2A Dehumidifier
I am having Daewoo refrigerator Model DIR220. When I switch on the refrigerator the compressor starts after about 3minuites and stops in few seconds. fan motor works continuously. As the compressor stops...
the compressor has an internal overload to protect it from overheating. the compressor is cooled by the refrigerant passing over it. It could be a bad compressor,, bad charge of refrigerant, or simply dirty coils not allowing air movement
Nov 26, 2009 | Dehumidifiers
On a coleman heat pump DRHS0421CB when the thermostat call for heat the heat pump compressor and fan start for an instant and then they stop and a failure message shows up on the thermostat. This works the...
If both the fan and compressor are going off the problem would be in the low voltage side a safety is opening. Probably low on refrigerant. You need to check refrigerant pressure when the unit is starting, if the pressure drops below 60 psig the low pressure switch will open and shut the compressor and fan off.
You really need to have a service technician check the system out for you.
Nov 22, 2009 | Dehumidifiers
My 1 yr old Zenith ZD30 dehumidifier just stopped working all together. The bucket is empty and I checked the to be sure that a circuit didnt trip. Any suggestions as to what it can be?
The Zenith ZD30 is made by LG as many other brands are also. There is a fuse located on the control board. That may have blown. I have also had 3 LG units come into my shop with bad control boards. If the fuse is ok. Measure the ohms at the power plug L1 to Neutral, with the unit unplugged. It should read around 430 ohms. The ones with bad boards read real high. Hope this helps.
Rasske's Renewed Appliances
Oct 20, 2009 | Dehumidifiers
Ijust bought a danby dehumidifier ddr5009. The compressor works fine but the fan never stops running. Even if I set the timer on standby.
This dehumidifier is built in such a way that the fan runs all the time;however the compressor works only when it is needed. These infos are not specified in the booklet. It does not work like the old ones.
Sep 10, 2009 | Danby Dehumidifiers
Compressor stopped working after two days
It could be one of four things, a bad run capacitor, start capacitor, start relay or the
compressor is locked up.
I would think it's either the run capacitor. A lot of times you can look at it and if it's bulging even slightly then it's bad, if not it's probably the start capacitor and relay I add the relay in because when you change one you should change the other also..
Aug 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
The fan runs constantly. The compressor starts,
Check the compressor run capacitor first.
Jun 21, 2009 | Kenmore 53701 Dehumidifier
Compressor doesn't come on
Did you get a solution? I'm having same problem, same model
Jun 14, 2009 | Whirlpool Dehumidifiers
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Danby Premiere DDR5009REE 50 Pint Capacity Dehumidifier with 2 Fan Speeds, Electronic Controls, Adjustable Humidity Settings, Direct Drain Feature and 3,000 sq. ft. Coverage Area Logo
336 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
