Question about Sony SA-WM40 Subwoofer
The speaker will cut-out after it has been playing a while. It will click-off, like it is going into a power-save mode
2 Suggested Answers
Grubhead
  • 5193 Answers
SOURCE: The speaker will cut-out after it has been playing
Sounds like you have an heat sensitive semi-conductor that might be connected to a relay (the clicking thing). As it warms up it acts up!
You can pin it down by spraying suspected parts (while under power and when it acts up) with Servisol Freezer Spray. Only spray one part at a time. The faulty part will return to normal, till it warms up again, or you force it to by touching it with a soldering iron.
If nothing happens to the part you spray, it's working and test the next. Don't bother to spray non semiconductor parts.
Posted on Apr 15, 2010
Why does it go to auto mute, and how do i turn it off?
You did not mention which operating system you are using and it is a bit different in each.
XP: click start > click control panel > click display > click screen saver tab > click the power button > adjust timers to never > click apply
Windows 7: click start > control panel > power option > change plan options >adjust to never > save changes
Windows 8: swipe down right side > search "power" > click on power and sleep > adjust to never
Jan 18, 2014 | HP IDT High Definition Audio CODEC
I have an Alpine MRV-70 amplifier that cuts off completely every now and again. Power is cut off altogether and no sound plays. Main Power line, fuse and fuse holders have been checked. Amp plays perfect...
You are overloadign the amp with your speakers. They may be the incorrect ohms or simply too large for the amp causing it to go into protection mode intermittently.
Oct 21, 2013 | Alpine Car Audio & Video
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
I have a pair of Samson Live powered speakers. After about an hour of playing one woofer cuts out, then comes in for a little while, then cuts out again.
Hi, when a speaker shuts off like that it's usually indicates a Bad Transistor in the speaker.
The control circuit might be sensing a fluctuation in the power supply and it goes into a protection mode that's why it cuts off.
So you we need to replace the Transistor that is Bad. I guess that will solve the problem.
have a nice day...
Feb 17, 2011 | Audio Players & Recorders
Whenever i turn my pc on it says entering power save mode
Check the cables running from your computer to your monitor. This sounds like a problem with a cable connection. If you see your bios screen and then it says "Out of range" or something else, then you will need to go into safe mode and reconfigure your display resolution.
Jan 06, 2011 | Computers & Internet
The speaker will cut-out after it has been playing a while. It will click-off, like it is going into a power-save mode, then back on for a few seconds or minutes...then back off again.
Apr 12, 2010 | Sony SA-WM40 Subwoofer
ITunes will not play songs on my Logitech speakers
you can disable the sleep mode when you close the lid.
for windows xp
  1. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
for windows vista
  1. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
Feb 07, 2009 | Logitech V20 Portable Notebook Speakers -...
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
barneyluc
Oct 03, 2008 | Pioneer Audio Players & Recorders
When i put my headset to charge it stops charging after 5 seconds
if you are using the USB port on the computer to charge it, it may be an issue of your computer going into "Power Save" mode and shutting down the USB power. I found this by google searching "usb power save mode"... Possible Fix: 1. Click on "Start" and then right-click on "My Computer." 2. Click on "Properties" and then on the "Hardware" tab. 3. Half-way down on the right, click on "Device Manager." 4. Click the "plus" sign in front of "Universal Serial Bus Controllers." 5. Double-Click on the first "USB Root Hub" (not USB 2.0 Root Hub). 6. Click on the "Power Management" tab. 7. Uncheck the box that says "Allow the computer to turn off this device to save power." 8. Click "OK" and repeat for all other "USB Root Hubs." 9. Finally, close all and go back to the desktop.
Jun 07, 2007 | Motorola Mobility H700 Wireless Headset
Sony SA-WM40 Subwoofer Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
