Question about Garden
Lx 176 John Deere stopped running suddenly. Found this wire disconnected where does it go?
    New Friend:
  • 17 Answers
Probably the kill switch wire that would normally attach to the throttle linkage plate to complete a ground circuit for the ignition coil. If you can follow it and see if it ends up at the ignition/kill switch
Posted on Apr 29, 2013
lester482529
  • 226 Answers
SOURCE: I need a belt diagram for my lawn mower>
PART'S TREE.COM HOPE THIS HELPS
Posted on Jun 09, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
SOURCE: john deere runs then stops
I fixed my mower stalling issues on the L111 by loosening the gas cap. I ultimately drilled a hole in the gas cap and screened the hole. Sounds ridiculous but without that venting the engine would run approximately 20 mins and die. It was also much more difficult to start the next time. Something else to pass along to whomever might view this... I replaced the cranking battery with a battery that had allot more cranking amps and I no longer had hard start issues ( this was after I vented the gas cap). Hope this helps.
Posted on Aug 11, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
Need owners manual for john deere lx 280
Here is a manual that I found on the internet for you!
It can be printed or navigated using the links on the left hand side of the page.
http://manuals.deere.com/cceomview/OMM152799_I4/Output/Index.html?tM=HO
Sep 03, 2015 | John Deere Garden
I have a 2010 John Deere 777 Riding Lawn Mower that stop cutting all of a sudden as I was mowing this morning. Do you have any idea why?
Cutting or running? Big difference..if stopped cutting most likely your belts came off the pulley or broke...have to take a look..Stopped running need more info...good luck..
Aug 25, 2015 | John Deere Garden
John deere lawn tractor not getting spark on left side?
check wire maybe broken inside they do wear out
Jul 26, 2014 | John Deere Garden
John Deere LX 255 does not move
most likely its the drive belt.
Jun 14, 2012 | John Deere Garden
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jul 10, 2009 | Garden
John deere lx 178 1 cylinder firing
pull plug if its wet you have a firing problem if not the you have a fuel problem! been my expierence use only jd parts on that bad boy! little more $ save you several little head aches!
May 26, 2009 | Garden
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
