Question about Briggs & Stratton Garden
Leaking gas directly from primer - Briggs & Stratton Garden
  • 97 Answers
Make sure hose is connected and not cracked or broken
Posted on Dec 28, 2013
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
Gas leaks out of carb or primer bulb
Is it leaking out of the carb or the primer bulb.
Could be a split fuel line, split primer bulb, or a sticky needle valve in the carb
May 21, 2016 | Garden
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
How to get gas on primer bulb
Make sure your fuel lines are tight and not leaking. I would also change the fuel filter that is in the gas tank.
May 03, 2016 | Garden
Leaks gas probloms strating
check your fuel line to the primer or the primer bulb. if it is leaking you will not prime properly and won't run properly due to sucking air instead of fuel.
Feb 21, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
What will caus a primer bulb to leak gas directly from bulb on a craftsman snow blower ? I open the fule line at the tank and prime to start engin. Primer bulb leaks fule at center hole till i shut off...
Your primer bulb has a small hole in it, due to dry rot, you can take the bulb off and replace it with a new one very easy to replace, 4 screws, it is like a gasket.
Dec 07, 2009 | Audio Players & Recorders
16" craftsman chainsaw primer pfoblem
Check the condition of the fuel line and filter in the tank and to the carb and primer.Today gas and time will soften them allowing them to become blocked or leak.Replace if needed.
Oct 24, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Gas leaking in a stream from other end of primer line
Something is causing the float in the carb to stick in a downward position. This float tells the carb when to cut off the flow, and stuck down it keeps the channel open for gas to flow through. Empty the gas and remove and thoroughly clean out the carb, making sure you hit the float bowl very well. Worst case the float could be bad. If cleaning it thoroughly doesn't get it, consider a carb rebuild kit from the engine manufacturer or replacing the carb.
May 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
14 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
