Question about Panasonic Lumix DMC-FZ10 Digital Camera
DMC FZ-7 Zoom
Hi, I have a Panasonic DMC-FZ7 digital camera, the zoom will not work. Can you give me an estimate on the price to fix... Not under warranty. Do you know where this can be reparied? Thanks,
  • Anonymous Dec 17, 2007
    i have a panasonic dmc-fz7 my zoom is very fuzzy at 8-12 power. what can i do ( or you do ) to fix this problem
    Genius:
  • 2,985 Answers
Check the makers website- they will give you an estimate- which I guess will be nearly as much a buying a new camera . Thats the way it goes.
Posted on Aug 03, 2007
SOURCE:
My zoom is behaving badly...camera is working fine ontil i want to use Zoom ...it will not stop until it reaches the 12x position ...takes photo here fine but nothing inbetween ???
Sounds like the zoom switch is broken. Repair is possible, but is best left to a professional technician. Check with your local service centers.
Jul 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Where is the lever on the panasonic dmc-fz7 for the zoom
It's around the shutter button. "w"for wide and "t" for telephoto.
Apr 25, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
DMC-FZ7 Panasonic digital camera won't focus when zoomed
Your camera focus problem mostly deal with machanical parts. So changing them easily will solve the problem. But unfortunately you may not do it yourself. Because it is highly complicated process. In deed it needs lots of repairing devices which are found only in services. According to me the service had given you the best answer. Please accept their advice. Good luck.
Mar 04, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Optical zoom and flash not working on Panasonic DMC-FZ7
None of what you describe sounds good. Any chance you can get your money back?
Dec 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
No zooming
sorry but the dmc-fz7 does not have a zoom ring only a zoom control on the top right.
Apr 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic DMC_F27 won't zoom
contact panasonic, or go to a local camera shop. it sounds as if its broken and needs a repair
Sep 03, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Low light situation
Where the Panasonic FZ-20 does very well, is with conditions where you need a long zoom under low light. Most lenses will lose light as they are zoomed out. The Leica lens in the FZ-20 does not lose light when zoomed. No matter which camera you are using, you will have to use the manual controls for the best results. So learning about exposure and how to use it, is necessary.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ10 Digital Camera Logo
135 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
