Question about Presto Kitchen Appliances - Others
Cool Daddy deep fryers
Electrical Problem. There is power to the control switch, Switch appears to work. the white wire has some kind of censor, resistor, heat sensor, Fuse ?, this is attached to the side of the appliance it comes in contact with the cooking oil container. I put a ohm meter test starts out at 24 then drops to 0 at a slow rate. I put a cont unity test on it no continuity. could this be a fuse. This is on the negative side (White wire) confused
  • 3 Answers
SOURCE: Rival 3-L Cool Touch Deep Fryer
It sounds to me like it could be one of two things.
Either the magnetic cord safety thingy came slightly undone (which happens to mine constantly) or you didn't turn the timer to "always on".
The thermostat itself does not turn the heating element on, you must turn the timer to always on to preheat the oil, then when it's heated you can set what time you want to fry for.
Posted on Nov 18, 2007
  • 77 Answers
SOURCE: DEEP FRYER WONT HEAT
have you tried taking out all of the oil and washing it realy good I know that mine wasnt working and thats what i did and it started heating up again
Posted on Feb 19, 2008
burzerko
  • 254 Answers
SOURCE: fryer quits heating have to hit reset switch
This button should be a high limit switch. If it is a small red button mounted to a 2" x 2" or so device. You most likley have an issue with the thermostat letting it over heat. The best thing to do would be to replace both the thermostat and the high limit for safety reasons.
Posted on Jun 17, 2008
SOURCE: Gaggenu VF 112-610 Deep Fryer
www.gaggenau.com has a service link. The site is not really user friendly so enter the model number as VF 112610 and select the parts list. The heating element is listed at 158.00.
SOURCE: star deep fat fryer model #EM14
You should determine how many amps the unit is pulling, you will need an ammeter to do this. Continuity through the internal circuit breaker does not determine the current being pulled by fryer only that it can pull current. If the fryer is pulling more than 50 amps the problem will be in the fryer, if it is less than 50 and the breaker trips you could have a faulty breaker.
Posted on May 30, 2009
Why doesnt my deep fryer heat up ?
First it is good to check the fuse by unscrewing the plug.
If the fuse wire is not broken, it means that the deep fryer could be broken.
Nov 21, 2015 | Farberware Home Electric Faberware Deep...
Reset switch uniworld electric counter top deep fryer
There is no reset switch. If there is a problem, a repair must be made to make the deep fryer work properly again.
May 20, 2014 | Frymaster Dean SR42G Deep Fryer
Need an instruction manual for the Presto Fry Daddy..where can I get one and how much is it?
Your Instructions for the Presto 05420 FryDaddy Electric Deep Fryer can be downloaded from the following site:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000008244.pdf
Thank you for using FixYa!
Sep 19, 2011 | Presto 05420 FryDaddy Deep Fryer
The 480 volt Garland deep fryer appears to have power to it. Model # e24-31f. I think the hi temp cutout is what is keeping it from working, but I can't find it. The fryer is bolted down and access to the...
If it is electric the high limit should be on the top back of the elements kind of behind the fryyer does tthis pivotup and down so the vat can be cleaned.the highlimit will be very small red button.
Feb 25, 2011 | Garland AF-5025 Deep Fryer
Find a manual for presto cool daddy deep fryer
You can download the manual for your 05442 CoolDaddy Fryer on the Presto website:
http://www.gopresto.com/products/manuals.php
Hope that helps!
Jun 15, 2010 | Presto 05442 CoolDaddy Deep Fryer
T-fal 4017 deep fryer will not turn on
the reset switch is a miss print in the manual. call this number 1-800-557-4825 they will replace it for free if it is still under warranty
Jan 20, 2009 | Rival CZF530 Deep Fryer
Presto 05443 Cool Daddy
Call customer service with the complete model number at 800-877-0441.
Mar 18, 2008 | Presto 05444 CoolDaddy Cool Touch Deep...
Cuts off
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
Dec 16, 2007 | GE 168997 Deep Fryer
Kitchen Appliances - Others Logo
54 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
ZenFire
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
