Question about ViewSonic VG900b 19" LCD Monitor
Vga cable and power cord for monitor
What type or name of vga cable and power cord for my viewsonic monitor
  • 1,684 Answers
The AC adapters are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=136
And the VGA cables are available from the same site at this link:
http://www.ccl-la.com/catalog/product_info.php?products_id=54
I hope this helps,
BuddyMc
Posted on Sep 11, 2012
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Posted on Apr 03, 2009
I get a bright pink background on the monitor, this lessens in intensity from time to time, then returns to normal. I am hoping the monitor is not "giving up". or does it need degaussing, if so how please.
There is no degaussing to LCD monitors. The function is related with CRT type monitors and TVs.
The problem to your monitor should be either with its back light, or loose contact to the insertion sockets to LVDS cable. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 19, 2014 | ViewSonic VG930m LCD Monitor
Need a Monitor cord. What should I get?
If it is a signal cord from computer, you want to get a VGA cord. if it is a power cord, Same as a power cord for acomputer, and you can get them at radio shack, of best buy.
Aug 11, 2011 | ViewSonic Optiquest Q53 (White) 15 in.CRT...
ViewSonic VG2030wm speakers not working
you are unable to get an image on your ViewSonic monitor, first check that the necessary cables are attached correctly and that the proper drivers are installed. ViewSonic offers drivers for download directly through its website (see Resources).
Some LCD monitors use a VGA input while others take advantage of the newer DVI interface to provide a connection to PCs (some ViewSonic monitors offer both types). When connecting your monitor for the first time, you'll need the right type of cable for both your monitor and computer. In some cases an adapter may be necessary to convert the DVI signal from your monitor to work in a VGA input on your PC.
Check that the VGA or DVI cable is tightly attached to the back of your monitor and to the back of your PC. Use the small thumb screws on the ends of the connectors to keep everything tightened in place, which will prevent the cable from getting loose.
ViewSonic monitors also use a power cable to plug into a power source. If the power light does not comes on, check that the power cable is inserted fully into the back of the monitor and that it is plugged into a working wall outlet or a reliable surge protector.
Mar 06, 2010 | ViewSonic VG2030wm LCD Monitor
ViewSonic VG2021m monitor without installation software
try using the FN "function key" and you should have a button at the top that looks like and LCD press it while holding the FN button
Dec 16, 2009 | ViewSonic VG2021m LCD Monitor
Powersuply
OPEN UP YOUR PHONE BOOK OR YELLOW PAGES OR ONLINE LOOK UP COMPUTER SPECAILIST,
YOU WANT COMPUTER CABLING SPECALITY THEY CAN MAKE ANY TYPE OF CABLE OR CONNECT YOU CAN THINK OF AND EVEN HARD WIRE A CORD INTO YOUR SYSTEM SO YOU NEVER LOOSE ANOTHER ONE.
CANDYMANGANDY
Jan 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Won't power on. No lights at all.
You have done Most of it...
You have tried to swap the Power cords that work fine with the Other Monitors and If that do not work there are 2 things externally that could be bad.
1-> The Power Button.
2-> The Port where you would Plug in the Power cable.
so Check if the Power button is stuck or Broken, or Loose out of control.
besides that If with one of the good power cord connected when you connect an external Head phone and you receive some Kind of sound out of it.,
It could be because of the Display settings.
you can try the monitor self test.
By having the Monitor Unpluged from the computer but still connected to the power.
you would see a message that shows, that the VGA cable is not pluged in if that shows your Monitor is fine otherwise it is BAD.
Jul 17, 2008 | ViewSonic VX924 19" LCD Monitor
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
ViewSonic VG900b 19" LCD Monitor Logo
269 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
