Question about Hayward Pool & Spa
How do we remove the laterals, they seem to be stuck
The laterals are not unscrewing
Hi, I just did mine and they had never been removed (12 years). Mine were also stuck so first, I sprayed a small quantity of WD40 at the base of each lateral and went for lunch. Then I rinsed everything as best I could with clear water to remove as much sand and gravel. I then used hot water to rinse again and they unscrewed pretty easily. Have fun!
Posted on Jun 04, 2013
My son put tp down the drain. How do I remove the sink stopper? Doesn't seem to unscrew?
it unscrews but from the underneath up
you will have to remove the "S" trap only as what ever it is will be stuck in that bend
Jan 04, 2016 | Plumbing
How do I open the filter cover on my machine .it came with the house. it seems stuck solid.please help regardsmary
Assume its a washing machine. If stuck solid it is probably scaled up. I had this problem,and managed to unscrew it using a plumbers wrench. You will hear a crack as the scale breaks up, and can clean thoroughly once removed. I replaced my filter, only 3 quid on ebay. Now cleaning it monthly !
Mar 03, 2015 | Washing Machines
Trying to remove screws from base of plasma 32lg60ur, but screws won't come out seems as if screws are stuck(obstruction) help please
Hi Anita,
have you tried using an aerosol freezer compound the is available from Maplin stores, freeze the head of the screws so they contract and try to unscrew them? have a go this worked a lot of the time when I was in the tv repair game doing vcr's with screws that were stuck.
Oct 16, 2014 | Televison & Video
CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7...
I had to completely unscrew and disassemble the printer then cut or break the piece of plastic from the removable ink cassette that was blocking it from being removed. See attached pic.1_3_2013_5_05_41_pm.jpg
May 18, 2010 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Cannot unscrew housing around water filter seems stuck,
Open the freezer side and turn ice maker off. Leave freezer side open and try unscrewing the filter housing again. It will still be snug but keep turning and it will come off. Mine was stuck too but this worked. Good luck.
Jan 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Whirlaway 191 Garbage Disposal hardware is stuck on sink
If your unit has the ISE type mount as shown in the image (three screws), you should be able to back those three screws out, push up on the flange that the screws went through, and remove the snap ring from the groove. The whole assembly will come apart at that point.
Dec 24, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
Trying to remove built in Kenmore microwave 1994 #89755?
A family member removed it while I was away. Returned home a short time later & it was outside under the C/P. Thanks anyway.
A.J.M.
Dec 30, 2008 | Kenmore 62622 Microwave Oven
Replacing the protective panel
http://www.tvscreenrepair.com
Im going to be replacing mine. There was a blog someplace on how to replace it, but I cant find it now. Be sure to only remove the front panel (speaker cover) and not the back because the mirrors will break.
Jan 15, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
