Question about Garden
Troy bilt riding mower not firing
Last fall I hit a root and the mower died. I just checked the flywheel key and it is good. But it still isn't firing a lick. Any pointers?
  • 7,482 Answers
Hi bgauvey
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 08, 2013
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: How do u change the oil in a troy bilt lawn mower?
Set it up on a work bench or table of some sort with the dipstick at the outside edge of the table. Remove the dipstick and turn the mower on its side dumping the oil out the dipstick tube into a suitable container.
Don't do like my daughter did when I told her how to do this, she took a container that her dog had played with and bit holes in it, now she has a nice oily spot in her back yard LOL
Posted on Oct 02, 2009
  • 85 Answers
SOURCE: i have a model 13aq609g063 troy bilt riding mower.
Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
Posted on Nov 08, 2009
  • 6468 Answers
SOURCE: How do you put a mulching blade on a troy bilt 21
remove the center bolt from under the machine put a block of wood against the blade to hold it from turning on you
Posted on Aug 20, 2012
I have a Troy Built 42 in cut riding lawn mower with the Kholer Courage 19hp engine. The other day I was cutting and it just sputtered and died. Since then it will not start.
if it is back firing it has to do with timing. if you hit something is usually the cause. i would take the cover off of the engine and be sure the flywheel key is not sheared if it is replace it. if that is not it take the cover off of the valves and see if a push rod has broke or the valves are out of spec. they should be intake .004 and exhaust .006 if you set them both at .005 that is good . flywheel key or valves.
Jun 08, 2017 | Troy Garden
Troy bilt
It thinks that the PTO is on. Do you have two different key positions? If so try both for a temp fix. If not it's probably a linkage or switch problem.
Aug 02, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Pull mower rope on troy built self propelled mower and it jerks it back out of your hand,hard,,and will not start
This sounds like the engine is out of time.
Usually this happens when the blades hit something hard and shears a small aluminum"key" between the crank shaft and the flywheel.
This is reparable. The little key is less than a buck. A person needs some skills to remove the flywheel to replace the "key".
Wayne
Jul 30, 2010 | Troy Garden
Troy Bilt model 60TG I hit a small piece of wood and the tractor
If you haven't already, check to see if there is a hunk of wood wedged between the blade(s) and mower deck. I've seen that happen. I pried the hunk of wood out with a crowbar and life was good again. The second time, someone ran over a campfire log they didn't see under leaves last fall and bent the blade spindle. It basically froze the spindle in place even though there wasn't anything wedged in there. I removed the belt from the top of the mower deck and then it started just fine..... although the blades and shaft were toast and had to be replaced. If you can disengage the mower deck without removing the belt(s), try it if you haven't already. See if it starts that way. If not, the issue may be more serious such as a broken connecting rod in the engine. Try the simple stuff above first to troubleshoot the cause.
Apr 30, 2010 | Garden
Troy-Bilt Mower is running real slow like its clogged dont know not a mower expert, need help please before I take it to a mower expert.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Sep 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Jul 31, 2009 | Garden
Troy bilt pony riding mower will go in reverse but grinds in forward where do i start
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Jul 17, 2009 | Garden
Idles really high after changing the bag and hitting rock
You may have partially sheared the flywheel key when you hit the rock and this will change the timing.
Good Luck
Bart
Jun 11, 2009 | Troy Bilt 5.5hp Self Propelled Mower
18hp/ohv craftsman 42in wont crank
One thing to check, see if there is a piece of root stuck under the tractor there is interrupting any of the security features from allowing the tractor to start. It might be a small piece that stops a plunger from engaging.
Mar 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Open Questions:
Garden Logo
443 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
