The tub spins so fast on the WASH cycle that the clothes centrifuged away from the agitator making it useless. A burning rubber smell lead me to change the belt but that did not fix the problem. I figure the problem with the tub is the same that melted the belt. Any tips? Yes, the agitator works and the spin cycle works just fine.
Sounds like u have a problem with the "brain". The agitator and spin cycle should never run at the same time. therefore it leads me to A: brain issue B:problem in the actual transmission of what cycle should be running. You will continue to smell the burning rubber due to the issue being one of the two explained above. Does it ever NOT spin? If this is the case the likely hood is that it will be a solenoid.
