Question about Radio Communications
Delco car stereo 2001 Tahoe
My clock stopped on the screen. Although it's right twice a day, I'd like to replace the little $2 crystal that makes it tick. Anybody know what the frequency of the crystal is and it's location? I see two inside.. 56768 ll and 46714 oz is the way they're marked... can't fine anything online.
  • Radio Commun... Master
  • 15,667 Answers
What makes you believe it is the chrystal? Chrystals dont fail very often.
Posted on Jun 10, 2013
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
Delco factory stereo replacement
Yes, it is fine. You can replace old version music system to new delco 16166166 radio and cd. It works fine but yes it would be better to take your car at service centre for replacement instead of doing yourself.
Drivers dream days discount codes
May 28, 2014 | 1992 Cadillac Eldorado
Am-fm doesn't work on radio 2001 tahoe, everything else works, what could be the problem
Antenna connection is the place I'd start with. Something is wrong with the cable or the connector.
Aug 23, 2012 | ACDelco 2001-2006 AC DELCO-FW311 Chevy...
2000 chevy tahoe speaker wiring
This will depend on whether it's a Bose system, or not.
Non-Bose AC/Delco radioFront Speakers are:L. (-) Light GrayL. (+) TanR. (-) Lt. GreenR. (+) Dk. Green
Rear:L. (-)YellowL. (+)BrownR. (-)Lt. BlueR. (+)Dk. Blue
Be sure to test the connections, as you will notice that there are 2 Yellow wires, 2 Brown wires and 2 grey wires behind the factory radio.
GM pairs all the speakers into separate 4-pin plugs for front and rear. If the factory harness is intact, I'd suggest just getting wire harness adapter from any of your local car audio shops, you'll also need a GM mini antenna adapter, if you are hooking up a new stereo.
Jun 05, 2012 | Chevrolet Tahoe Cars & Trucks
My 2003 chevy tahoe won't start in the morning
Many possible causes....Too little info to make an intelligent suggestion. Try charging the problem vehicle's battery with jumper cables for 2 minutes with the supply vehicle running at fast idle (or about 1500-2000 RPM, if it is tachometer equipped) before you try to crank the problem vehicle on a cold morning. If it starts right up, you likely have a weak battery that needs replacing.
Feb 13, 2012 | 2003 Chevrolet Tahoe
Does anybody have any idea want could be wrong with my 2001 chevy tahoe??I replaced my fuel pump 2 yrs ago but now these past few weeks.I can drive about 6 to 8 miles away all day long stopping places and...
I had the same problem with my 1996 tahoe and it wound up that the fuel pump was going bad and then finally did go out completely. make sure you get an a/c delco or delphi fuel pump as they are much better than the cheaper aftermarket brands that fail after about 1 year or so. also, make sure they check the fuel pump relay located under your hood on the driver's side in the main fuse box. its about 10 bucks or so and also will cause your truck to die and not start again. it's well worth the investment to just replace it when doing the fuel pump. lastly, make sure they install a new wiring harned from the fuel pump in your gas tank to the electrical connector running to the engine. hopes this helps.
Oct 21, 2011 | 2001 Chevrolet Tahoe
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
I can't figure out how to set the clock on my aftermarket delco loc-ii compact disc car stereo
I don't know how my question got posted under a 1993 Chevy k1500 truck. My problem was trying to figure out how to set a clock on an aftermarket Delco loc-II am/fm cd car stereo. And NO, I still have not found my answer.
Feb 18, 2009 | 1993 Chevrolet K1500
2001 Chevy Tahoe radio problem
Your Display will Eventually Stop alltogether. Happened on my 2000 Blazer and had to replace with Aftermarket Stereo. Dealer wanted WAY too much for new unit.
Jan 04, 2009 | 2001 Chevrolet Tahoe
Lock out code
I've heard of people using Delco Lock Codes (http://www.delcolockcodes.com) to get their radios unlocked. They seems like a legit site from what I've read. Good luck!!
Oct 26, 2008 | 1998 Chevrolet Tahoe
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
