Question about Panasonic NNSD277SR Microwave Oven
NN-SD277SR - has power as light & fan work but when trying to cook it stays on for a few seconds and shuts off. Started out like this a few months back and when power level was reduced the unit would cook....now it won't even cook at power level 3 and won't stay on at all. Any ideas?
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: operates for 3 seconds on microwave then stops
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
SOURCE: Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
Posted on Jan 07, 2009
joust
  • 7 Answers
SOURCE: Panasonic NNC980 - stops working after 3 seconds
you have a bad inverter board.
Posted on Feb 16, 2009
Fan & Light stays on???
On a few new model microwave ovens, this is a "feature"! It's purpose is to cool the microwave parts down, and to remind you that your food is cooked. Once you open the door, the fan will shut off and stay off when you close the door again. But if not, or if you microwave oven didn't use to do this, then you have a bad door switch.
Sep 08, 2014 | Microwave Ovens
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Panasonic Model NN T964SF inverter microwave runs for less than 5 seconds and shuts off. Power control function does not work either. Pressing power control a number overrides cook time with power...
In most cases, this is a problem with the inverter or a bad magnetron.
Aug 02, 2008 | Microwave Ovens
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
Panasonic NNSD277SR Microwave Oven Logo
21 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
