Question about Olympus Camedia C-4040 Zoom Digital Camera
How to use the camera in right way - Olympus Camedia C-4040 Zoom Digital Camera
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
If i lost my usb wire to my camera how do put the the pictures on my computer
You can purchase a new cable at most stores that sell computer hardware. Just take the camera with you so you get the right one. Camera manual is online at Page 29 of DXG DXG 308 User Manual ManualsOnline com Amazon has a list of stores that sell different USB cables Fast Reliable Power with 2 year warranty As well as Ebay, you just have to get the right USB with the right size camera end.
May 27, 2014 | DXG Technology DXG-308 Digital Camera
I have instaled the cam right and my pc doesnt pick it up
You need to go into Device Manager:
On XP:
  • From Control Panel, choose Classic view
  • Double click on System
  • Click on Hardware Tab
  • Click on Device Manager
  • Locate the driver with the yellow triangle
  • Right click and delete it
  • Uninstall the camera software from Add/Remove Programs
  • Reinstall the camera software and it should install the drivers in the right place
On Vista/7:
  • From Control Panel choose either Classic view or Large Icons
  • Double click on Device Manager
  • Locate the driver with the yellow triangle, right click and delete it.
  • Uninstall the camera software from Programs and Features
Jul 25, 2011 | Cameras
Does it work.....
Hello!
Please, make sure your camera is installed:
  1. Start>right click Computer>Manage>Device Manager
  2. Try to find your camera in the list of drivers.
  • If not there, it is not installed, so in that case go to this link: http://www.trust.com/products/product.aspx?artnr=14382 and download the driver (right bottom of the page>quick links>download driver)
  • If there, check if it is marked with yellow triangle: if yes, right click on it and Uninstall, then restart computer and install the camera using the downloaded driver: double click on the driver, and Run>Allow/Continue>plug in the camera if prompted. When installation is done, unplug the camera and restart computer.
3. If you only want to check is your camera works properly: follow the steps from 1., find the camera in the list of drivers, right click on it>Properties>General tab and you will see the information. If you find the camera is not working properly, uninstall it like in 2.b., restart and reinstall the camera following steps provided in 2.b.
Regards!
Jul 03, 2011 | Trust WB-1400T Webcam
I dont know how to use the video camera
To use the video camera: check the lower right portion of the camera. The last button there is the function mode. just move it right (notice the image of video there.) You can now start using the video camera.
Hope this one helps.
Oct 06, 2010 | Nikon COOLPIX L4 Digital Camera
My camera turn right off when i tirn it on
suspect battery is low.
suspect battery has not charged properly in charger.
suspect battery may be defective.
suspect camera is defective.
i would ask a specialist at a camera store to check this.
Nov 15, 2009 | Sanyo VPC-S1080 Digital Camera
See the "Your Problem:" above, the package hasn't worked.
sounds like its not installing the drivers right click start menu button, right click computer, click manage go to device manager and see if the camera drivers are installed right, with the camera plugged in if not keep the camera plugged in stick the cd in, right click on the camera in the device manager and click update click browse my computer and select the cd that came with your camera now it should have the right drivers and it should work
May 03, 2009 | Computers & Internet
At power on, lens comes out then goes in/out tehn told to restart
intialize camera first. press the playback or review button while camera is turned off. then go to menu, go right to setup, press right arrow on setup, go down to setup1, press right arrow, highlight initialize, press right arrow, select ok with the middle button. if this does not work, try removing battery for 30 seconds then reinsert it. if these steps would not resolve issue then camera needs service. www.sony.com/repair.
Mar 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Dec 23, 2008 | HP Photosmart R817 Digital Camera
Red dot
I suspect that your intsructions might help you find out what this red dot indicates. I have had customers send their cameras in for service complaining about a dark rectangle in the lower right hand corner of their Olympus cameras' LCD. Turns out it was the exposure "burst" counter. If you don't find your answer, we are always here!
Mar 26, 2007 | Samsung Digimax L60 Digital Camera
Settings are reset
The camera can be set to retain all your camera settings each time the camera is turned off and on. Press the OK/MENU button. Then press the right arrow to access the Mode Menu. Press the down arrow to highlight the SETUP menu. Press the right arrow to highlight ALL RESET, and then press the right arrow again to highlight ON. Press the OK/MENU to save this setting and return to the Mode Menu. The camera will now retain any settings such as Quality each time you turn off the camera.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Olympus Camedia C-4040 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
