Question about Cisco linksys E3000 Wireless-n Router
Cisco e3000 router port forwarding
Port forwarding issues
    Prodigy:
    An expert who has answered 500 questions.
  • Cisco Expert
  • 537 Answers
Do a full power down and reset to default settings.
Posted on Nov 06, 2013
He code to the wi fi
The default password and login to the router are 'admin' and 'admin'. For instructions to log in to the router, see Linksys E3000 Login Instructions
Through these instructions, you can change the Wifi password.
Feb 11, 2015 | Cisco linksys E3000 Wireless-n Router
WHAT ARE THE PORT RANGES FOR ADDRESSES
Usable tcp and udp ports range from 1 to 65535. However you should not need to open any ports by default. Most routers include a stateful packet inspection (SPI) firewall. This is a fancy way of saying the router inspects the packet on it's way out to the internet when a computer on the inside of the firewall sends it out to the internet. The firewall will only allow connections from the internet on that TCP or UDP port if it returns from the original destination. For example, if you send a packet requesting the web page at cisco.com, the firewall will only allow traffic back into your network on TCP port 80 from the web server at cisco.com. If a packet from any other IP address tries to piggyback into your network through tcp port 80, the firewall will block it.
The only reason to open ports on your firewall is to allow a server inside your network to receive unsolicited traffic e.g. a web server inside your network may need TCP port 80 and 443 (HTTP and HTTPS) opened if you want to be able to access it from the internet. A mail server may need port 25 and 110 open for SMTP/POP e-mail. However, most home users do not host their own mail or web servers.
Mar 22, 2014 | Cisco Linksys Refurbished E3000...
Belkin N300 - CISCO Clean Access Agent
All configuration can be done with the router GUI.
Firewalls: Server Side Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine what port you will use to forward to this service. If there is only one server involved, you can use port 22 for ssh or 23 for telnet and forward them straight through to the server. But if there are several servers involved and they do not have public IP addresses, you will need to pick different ports on the firewall router and let the router forward those ports to the different internal servers.
Mar 01, 2013 | Belkin Surf N300 Wireless N Router
I have a new E3000 that i could log on to via remote connection, but i need to reboot it about 3 times a day. My wireless works after this reboot remotely. What could be the problem with this router?
there could be a problem with the firmware.
go to
http://homesupport.cisco.com/en-us/wireless/linksys/E3000
download the latest firmware for your router and reflash.
it could fix/resolve any bugs for your router.
May 26, 2011 | Linksys E3000 Wireless Router
How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
you need to setup both your xboxes with a static IP address for example
192.168.1.50 xbox 1 192.168.1.51 xbox 2
on your linksys router you will need to setup port forwards for both xboxes
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
requires you to forward the following ports: 53,80,88,1863,3074
Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have forgotten my passwork to my wireless cisco linksys E3000, how do I go about retrieving it?
he WEP key is defined by the person who set your wireless router up. You will not be able to find out what the WEP key is, but you CAN change it if you have physical access to the router. If you are trying to connect to your wireless router and can't remember the WEP, then walk over to the router and on the back or bottom of it is a small little hole that you can fit a pen or paper clip into. Press the paper clip into the little hole for 10 seconds and release. This will reset all the settings on your router back to default and will allow you to access your wireless connection.
Note: doing this will take away all of your wireless security so make sure that you know what you're doing before messing with it!
Thanks and please rate if this helps you at all :).
Mar 29, 2011 | Cisco Linksys Refurbished E3000...
I DON'T HAVE THE PASSWORD AND USERS MY CISCO E 3000
opened Cisco Connect under all programs and go to the router settings tab .
Aug 06, 2010 | Linksys E3000 Wireless Router
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Cisco linksys E3000 Wireless-n Router Logo
80 people viewed this question
Top Cisco Video Game Consoles & Games Experts
James Wishart
Are you a Cisco Video Game Console and Game Expert? Answer questions, earn points and help others
