Question about HP Officejet 6500 AllInOne InkJet Printer
Can the light be change in this printer?
Light is out on glass base
  • HP Master
  • 1,679 Answers
Try connect the printer to different wall outlet.
Regards,
Sean
Posted on Apr 22, 2013
Cleaning
Do you mean internally? Remove the toner cartridge. Get yourself an air blaster or can of air and blow any dust and toner out of the printer that you can - using a small soft brush like a paintbrush can be handy too. Use a soft lint-free cloth to wipe the rest out. If you want to clean the rollers isopropanol is good, but avoid contact with skin and eyes etc. Use a hi-alcohol based glass cleaner and glass cloth for any glass bits you find in there (like the laser unit window) if you want to clean the outside you can get this anti-static foam cleaner stuff which does the job well.. use with a light grade plastic scouring pad for those stubborn stains.. enjoy!
Aug 25, 2012 | Xerox Phaser 7760 Laser Printer
Tip
Cleaning your inside scanner glass
Actually it's a very simple procedure!
Read this entire comment first...then start your procedures!
Disconnect the power cord, disconnect the USB cable, remove the top cover cable from the base by unscrewing the two plastic knobs, lift the top cover straight up. Place the top cover in a safe place.
On a clean, flat surface, turn the base upside down. On both ends you will find a total of four (4) black phillips head screws. Carefully unscrew these four screws and place aside. Carefully lift up the base and the top glass will separate from the base. Set the base aside. You have now exposed the inside glass for cleaning! It's that simple!!! Clean the glass by using a streak-free glass cleaner. Don't spray the glass, rather, lightly spray a clean soft lint free glass cleaning cloth, then wipe the glass. Don't press hard! Use good common sense1 There, you've now cleaned the interior glass. Reverse the procedure and you are finished. Wasn't that simple??
on Feb 15, 2009 | HP Scanjet G4050 Flatbed Scanner
Tip
Actually it's a very simple procedure! This this entire comment first...then...
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Feb 15, 2009 | Epson Perfection V200 Flatbed Scanner
Printout is very light
You should clean the laser unit, and copie glass, and scanner glasses,..., replace developer, drum if needed...
Shortly: do PREVENTIVE MAINTENANCE on regular bases
Jun 14, 2010 | Ricoh Aficio 2035 Copier
Whirlpool GR450LXLQO range while changing oven
You will have to replace the light socket. Part number is 3150505 at approx. 30.00. Hope this helps
Feb 03, 2010 | Whirlpool Kitchen Ranges
Printer prints out black very light
First change you photo conductor unit if not solve
change the developer unit ( Ink ) If not solve
Clean the scanner glass of the printer.
Note that don't displace the glass just wash with a white dry cloth
Thanks
Oct 26, 2009 | Dell 5100cn Laser Printer
How can i replace the bulb for the center brake light on my 2004 odyssey
The lense should unscrew from the outside , some bulbs are push and turn and some are wedge base which just pull out.
push and turn bulbs have a metal base but the wedge base are all glass.
I changed a high stop bulb on a 2001 odyssey in this manner.
Jun 26, 2009 | 2004 Honda Odyssey
Oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Nov 12, 2008 | Whirlpool RF369LXPQ Electric Kitchen Range
Window glass
you need to buy one. unless your local glass shop can make you one. (you still need the sheild around the glass.
Oct 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Changing light bulb in a 25 year old freezer
Whatever you do, you MUST unplug the freezer before attempting any repairs... there will not be any release buttons, nor any special installations for water safety... also, take care to avoid cutting yourself on the broken glass..
1) did the whole light bulb glass And internals come out, or is the internal part of the bulb still present?
2) verify that the light bulb is really a screw-in appliance bulb -- look into the center of the broken bulb and see if the metal base has internal ridges -- or if the metal base is smooth on the inside...
3)  if a screw-in appliance bulb:  3a)  if the whole light bulb glass AND internals came out, you will have to probably look very close inside the socket to determine the wall of light bulb base... it should be very thin and flexible and very unlikely you can unscrew it directly -- I've had to take needle-nosed pliers and gently bend and twist until the bulb base came out...
3b)  if part of the glass remains as well as the internal stem, I have heard that one could cut a potato in half and then push the internal part of the potato onto the broken end of the bulb and gently unscrew the bulb by twisting the potato... never tried this so I don't know if it will work -- if the internal stem is still intact, I'd use my fingers and try to gently turn it to unscrew the bulb
4) if it has smooth inside wall -- this is probably a bulb with small exterior pins -- the base should be a little more thicker than the screw-in type, so you should be able to push the bulb base in -- a little give in the spring holding it in -- if you feel this give, then turn carefully counterclockwise and it should pop out...
Again, turn off all electrical power to the freezer, Pull the Plug before attempting any repairs... remove all glass and handle with care...
Jul 25, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
HP Officejet 6500 AllInOne InkJet Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
