Question about Craftsman Pressure Washer 2600 PSI, 2.3 GPM Honda Powered CA
Leaking from bottom
Bottom has three bolts and the housing for one bolt is craked
2006 audi leaks oil where transmission bolts to engine
black oil ,= rear main seal
red oil =torque converter oil seal leak
if the black oil is outside of the housing = rocker cover gasket leak or oil pressure sender leak
red oil outside of the housing = transmission oil cooler lines leak
Sep 09, 2017 | Audi Cars & Trucks
Can't find the 4th "bottom bolt" to disconnect the left headlight assembly on a 2005 lincoln TC
On the 2003 through 2005 models there are "three" bolts that secure the housing. Then pull housing forward and disconnect the electrical connectors.
Mar 07, 2015 | 2005 Lincoln Town Car
How do i replace my thermostat on my 2003 acura tl?
follow your upper radiator hose from the radiator back to the engine. At that point remove the hose and replace it. Put it back together , fill up the antifreeze and you are ready to go.
Jan 11, 2014 | 2002 Acura 3.2TL
Where is the thermostat location on 1998 ford taurus 3.0L 24V dohc
Just follow the top radiator hose to the engine. That is where the thermostat housing is located on most engines. The housing is held on by two or three bolts and is connected to the hose. Be carefull taking the bolts out. If they don't come out with minimal wrench force, the gasket around the housing has leaked antifreeze on the bottom bolt and rusted it tight. I snapped one off and had to have the car towed to my machanic to have it drilled out and retapped. It wasn't pretty and cost me an extra $80.00 to what shoud have been a simple job. You may want to consider getting stainless steel bolt to replace the stock bolts. They won't rust.
Jun 05, 2011 | Ford Taurus Cars & Trucks
Transmission pump leaks
Three reasons for leaks out of pump area( really 4 but the pump seal is never the leak)1 someone has not sealed the pan properly and fluid is seeping up through pan bolt hole into bell housing and leaking out.2 pump oring is old and hard due to heat and time (most common)3 someone has repaired a pump oring or rebuilt the transmiision and used a threade rod slide hammer to remove the pump(big no no) and damage the sealing area where the pump bolts seal(can silicone the bolts to fix this).I would pull the bottom pan and clean both surfaces with brake clean and allow the trans to drain for an hour , then apply a 1/8 inch bead of black or ultra grey pematex all the way around tthe clean dry pan( make sure you go to the inside of bolt holes and not the outside) allow the silicone to cure for 5 minutes before you mate the pan with the case.Good luck!
Mar 21, 2011 | 2000 Dodge Caravan
I was told that my differential is leaking and what parts do I need to fix it?
If it's just the gasket that leaking all you'll need is a socket set, gasket scraper and the gasket. If it's leaking at the yoke or axles it'll cost you more to buy the needed tools than to have a dealer fix it.
Jun 29, 2010 | 2004 Ford F150
OVERHEATING, CAN i CHANGE MY OWN THERMOSTAT?
yeah its not super hard locate wether the thermostat is at the end of the top hose or bottom hose then remove the two or three bolts holdin the housing on replace the thermostat and the gasket dont over tighten the bolts when outtin the houseing back on it will crack the houseing.coolant will leak out if u dont drain sum before u remove the thermostat housing.hope that helps if u need more info let me know
Apr 20, 2009 | Hyundai Elantra Cars & Trucks
Thermostat
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
  3. Remove the three bolts and position the A/C compressor aside.
  4. Remove the radiator hose clamp from the thermostat housing.
  5. Remove the radiator hose from the thermostat housing.
  6. Remove the three bolts and the thermostat housing.
  7. Remove the thermostat and the O-ring from the thermostat housing.
  8. Clean any corrosion or debris from the thermostat housing.
  9. Clean the mating surfaces.
  10. Inspect the thermostat.
To install:
WARNING Position the air bleed valve on the thermostat toward the top of the engine.
  1. Install the thermostat in the described position to the cylinder head.
  2. Install a new thermostat O-ring.
  3. Install the thermostat housing.
  4. Secure the thermostat housing with three bolts and tighten to 12 ft. lbs. (16 Nm).
  5. Install the A/C compressor and secure with three bolts. Tighten the A/C compressor bolts to 17 ft. lbs. (23 Nm).
  6. Install the radiator hose and clamp to the thermostat housing.
  7. Fill the radiator with approved coolant.
  8. Connect the negative battery cable.
  9. Start the engine.
  10. Allow the coolant to attain operating temperature (both hoses feel warm and the coolant is flowing through the radiator).
  11. Check for leaks in the cooling system.
  12. Shut off the engine.
  13. Install the radiator cap.
Short answer is that it is located in the housing that the TOP radiator hose is attached to at the engine block.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 05, 2009 | 2002 Chevrolet Tracker
Oil filter
On the front of the motor at the bottom just behind the front tire. The oil filter is inside the housing. There are three small nuts and one bolt to remove before you can get to the oil filter. On the front of the motor at the bottom just behind the front tire. The oil filter is inside the housing. There are three small nuts and one bolt to remove before you can get to the oil filter.
Nov 10, 2008 | 1983 Suzuki GS 650 GT
Craftsman Pressure Washer 2600 PSI, 2.3 GPM Honda Powered CA Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
