Question about Philips PD9012/37 DVD Player
Sound isn't working
Volume is extremely low
I puchased a Behringer EPX2000 and I am not getting much volume out of it.
As you can see in these pics ,
http://www.avsforum.com/t/1236585/inside-pics-of-behringer-epx2000
, this is not a simple unit to troubleshoot. I need to know more about how you are using it, it needs some sort of preamp system or mixer board to drive it. Behringer stuff is also something extremely hard to find parts for, they are custom made for Behringer. Most power amps are made to be driven because the line in signal is very low for that reason. Let me know a little more info and I can help you more.
Mar 29, 2013 | Behringer EPX 2000 EUROPOWER
Does anyone have low volume during playback on the toshiba camileo x100?
you can make the audio louder. see about raising the volume and then when playback make sure it's not too loud. If that doesn't work then the cameras is set low in the audio. see manufacturer if they have a solution. or in the camera see if there is a volume control, maybe it's set low.
Sep 07, 2012 | Toshiba Camileo Video Cameras
Why isn't my volume working?
there are numerous volumes - in-call (which you can only increase/decrease while sspeaking to someone) media -volume (which a game or music has to be playing to change) and the phone volume (which all other programs must not be running through the volume.
Also check your settings - sounds - and make sure your phone is NOT on silent..
May 09, 2012 | Cell Phones
Wotcha, i've just taken amp out of storage, has'nt been used for a while cant get volume to work properly the sound goes from speaker to speaker and up and down in volume whilst crackeling a lot as...
One way of proving it ISN'T the amp circuitry is to remove the pre-main jumpers and jack in a source that has its own volume control (or try a CD that starts really low) because this bypasses ALL the amps controls. If it sounds ok (albeit LOUD) I'd suspect oxidized contacts on the controls. Turn it off and vigorously operate all controls a zillion times to wear through it. In mosty cases it's the unused controls that fail because they never get wiped. Maybe a shot of contact cleaner on those you can access.
http://www.overload.it/supporto/643/manuali/NAD-C350.pdf
Oct 15, 2011 | NAD C350 2-Channel Amplifier
The reciver turns on and everthing seems to be working, but no sound comes out. i but it all the way up,and you can here it very low..........
What product?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING or any real world purpose.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Sep 02, 2011 | Audio Players & Recorders
My NAD T65 receiver has problems with the digital sound input. The sound gets choppy when I increase the volume. It seems to be ok at very low volumes, but as soon as I crank it up it fails. It happened...
Could the amp be showing distress, clipping, going into protection? There really isn't much reason for volume of a digital input to have an effect unless the room is shaking so much it's upsetting the digital source device's tracking.
http://www.retrevo.com/support/NAD-T765-Receivers-manual/id/23031ag215/t/2/
Aug 15, 2011 | NAD T765
Hello! I'm having problems during a phone call with my speaker volume being too low unless speaker phone is on. All other sounds are loud & clear. I've tried resetting & turning the phone...
Did you happen to update to iOS 5? Because since the update. Mine has been the same way. The volume is very low. and sometimes even the speaker isn't too loud either unless I'm playing music.
If you did not update to iOS 5. Then your speaker might be blocked and easily cleaned with a cotton swab, or the speaker is just old and going out.
Jul 25, 2011 | Apple iPhone 3GS Black (16 GB)
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Jun 14, 2011 | Televison & Video
I had a virus. had my computer cleaned. everything works perfect. except no sound from my speakers. they are connected and not muted. help
Make sure the computer volume itself isn't muted and is not set really low. Check to see you actually have sound drivers installed and the right output selected.
Jun 10, 2011 | Microsoft Windows Vista Ultimate Edition
I accidentaly destroyed my volume wheel while on low sound volume. how to put the volume back to high.
Hello!
What operating system?
There should be a volume control icon in your system tray (if it is windows).
If there isn't go to Control Panel-> Audio and there you will find your sound card properties.
May 26, 2011 | Toshiba Satellite M45-S351 Notebook
Philips PD9012/37 DVD Player Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
