Question about Troy Garden
Fuses are there any fuses that would keep the motor from turning
    Master:
  • 969 Answers
All electric start mowers has fuse in line. Refer to manual. Usually 20 or 30 amp.
Posted on May 24, 2014
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
My wiper fuse keeps burning out
If your wiper fuse keeps burning out, your wiper motor might be failing which causes too much amperes required to turn the motor which in turn trips the maximum rated amperes of the fuse.
Follow the wiring of that fuse to your wiper motor to make sure the wiring is not nicked and grounding to the metal. Once you confirm that there is no shorted wire, disconnect the wiper motors wiring connector. Fuse a new fuse and if the fuse does not blow anymore then you isolated the problem which is the wiper motor causing the fuse to blow. Fix or replace the wiper motor.
When diagnosing blown fuses, I usually temporarily replace any fuse in a vehicle with a circuit breaker type fuse. If there is still a short somewhere in the wiring or the component itself in line with the fuse, the circuit breaker fuse will just trip and I just reset it again after I fix the problem. An advantage of keeping to replace a blown fuse while diagnosing.
Oct 04, 2015 | Cars & Trucks
Why do i blow fuses when i turn on blower ?
blower motor is locked up either something inside cage is keeping it from turning or bearing is locked up and won't allow it to spin freely.
Motor is drawing to many amps through fuse because of resistance
Aug 08, 2014 | 1996 Dodge Dakota
Windshield wiper fuse keeps blowing when car is turned on or off
SHORT CIRCUIED MOTOR!!!TAKE THE CONNECTOR OUT FROM THE MOTOR REPLACE THE FUSE AND CHECK.IF FUSE OK REPLACE THE MOTOR.IF U NEED INFO SEND ME AN EMAIL TO SEND U INFO ON HOW TO REPLACE IT.IT IS QUITE EASY!!
Apr 01, 2014 | Volkswagen Beetle Cars & Trucks
Since you Disconnect the motor also renewed the switch and is still blowing the fuse ,it is obvious that you have either broken wire between the switch and the motor. Try to test the failure by means of a tester circuit. Good Luck.
Aug 21, 2012 | 2003 Mitsubishi Diamante
L999 Chevy Cavalier keeps blowing fuses and won't start
you have a SERIOUS electrical problem. - '.
BUT which fuses keep blowing - that is where we need to start.
1. is it the ignition circuit. - - does starter motor turn over when you trun the key.
2. is it the starter relay circuit.
3. is it the starter motor circuit.
4. is it the computer circuit. - - do you have fuel pumping to the engine and cylinders.
5. none of the above. - - do you have spark at the spark plugs.
Apr 14, 2011 | 1999 Chevrolet Cavalier
I have a 2000 Nissan Xterra and the 2 blower fuses keep blowing causing the the heat not to work. When I went to switch out the fuses the first time the motor and heat worked right away but only for a...
you have a problem with the motor circuit drawing more amperage than the fuse will allow. it could be the motor itself, or something that is keep the motor from turning freely. otherwise it's a wiring problem. i would suggest unplugging the motor, and then turning on the fan. hopefully, if there is some short to ground, which sounds unlikely, the fuse will blow. otherwise i suggest replacing the blower motor. good luck!
Jan 13, 2011 | Nissan Xterra Cars & Trucks
My 99 Ram 1500 keeps blowing the wiper fuse... I think it's a bad ground connection, but need a shematic to find it.
Fuses dont blow for bad connections, the blow because of a SHORT. Disconnect the wiper motor and then turn the switch on. if all is ok, then connect the wiper motor, if the fuse blows, the wiper motor MAY be bad
May 13, 2010 | 1999 Dodge Ram
1988 bmw 325is heater keeps blowing 30amp fuse, tried to find a short but me heater blower fan isnt working what could be the problem. cant keep a fuse without blowing
More than likely the fan motor its self is short to ground try to unhook the wires to the fan motor and install a new fuse and then turn the fan on with the wires removed and if the fuse is still good you know it is the fan motor its self
Feb 12, 2010 | 1988 BMW 3 Series
Garden Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
