Question about ViewSonic VX922 19" Monitor Flat Panel
Blue screen on my hp p1100
My monitor startsup normal but then immedietly everything turns blue. I thought it was the cable so i tried a new one, but the same problem appeared. what can i do to solve this problem?
  • 2,961 Answers
It may well be the problem is with your graphics card and not the monitor, next time you boot up press F8 to start windows in safe mode and select start windows in safe mode, this will load only the VGA graphics driver, so if the monitor stays on the problem is with the card or the driver and it's then down to illimination.
Posted on Aug 03, 2007
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Hp pavilion f1703 flashes on and off. Tried pushing F8 for 30 seconds - no result.
have you checked the power connecter at the back of the monitor?
is it the whole PC that is flashing on and off or JUSTr the monitor?
the F8 key when turning on a Windows based PC, will only take you to a screen to choose how to start windows, in Normal mode, safe mode, or commandline mode.
none of this helps a flickering screen.
try and change out the data cable (VGA cable, blue screw in plug) and the power cable if possible.
Sep 24, 2009 | HP Pavilion F1703 17" LCD Monitor
Blue hue on screen
Try a different known working monitor on the vga port of your laptop. If the replacement monitor works then you definitely know its a problem with your original monitor. If the replacement monitor shows the same blue hue then you know the vga port is bad on the laptop which would mean replacing the motherboard since its connected to the laptop.
May 30, 2009 | Acer AL2016W 20" LCD Monitor
Compaq P1100 Monitor
The monitor probably is no good.
Oct 22, 2017 | HP Compaq P1100 21" CRT Monitor
Monitor has dark wavy lines on edges
Well... sure it fixable, but it is going to cost you a bundles... Since you own this monitor for about 10 yrs. It's time for you to give yourself a new LCD monitor for the Holidays... :) Have nice day!
Oct 13, 2008 | HP Computers & Internet
Not coming on
check your connection on your graphics.make sure you have activated your screen on control panel-display-advanced.
May 12, 2008 | HP P1100 21" CRT Monitor
Picture problem
whats it plugged into.
my guess its plugged in to some unnamed PC.
try it on , another PC yet, that monitor ,new will no recognize old monitors.
test the monitor , then if its ok then the unstated PC is at fault./
you have 2 boxes there, 1 or other is faulting.
easy no?
May 19, 2017 | HP P1100 21" CRT Monitor
Small annoyance with HP P1100 monitor. Slightly darker vertical lines.
Sounds like dried out electrolytic caps. How old is the monitor ?
Dec 19, 2006 | HP P1100 21" CRT Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
26 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
