Question about Car Audio & Video
Memory problem Hi, I have a pioneer DEH-2220UB. I installed it in my 1999 Vauxhall Corsa. When i turn off the engine, and start it again, it forgets all of the radio stations and the eq settings too. What am I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Make sure the yellow wire is going to a constant power source. The yellow wire controls the memory and needs to have power going to it even when the key is off.
Posted on Apr 29, 2013
Testimonial: "Thanks for the help! :)"
robotek
  • 1512 Answers
SOURCE: pioneer cd radio deh-11 clock set
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Posted on Apr 11, 2008
SOURCE: Pioneer Super Tuner III DEH-45DH
I just bought a Ranger with the same problem... been surfing the internet and these are some of the answers.. I haven't tried any of them but I hope this helps:
<b>
Try pressing and holding the CLOCK button
while pressing the first
FM Preset button to change the hours
and the second FM Preset for the minutes!
We hope this helps!
turn the system off. Now hold down the function or audio button. It should light up the display with the time blinking. use the tuning and/or volume button to adjust hr/min, The rest is straightforward....
I just had to set mine and yes you turn the power off. Then you hold in the "F" button (just below "eject")" for 2-3 seconds. The time will display and the hour will blink. Use the up down arrows to change the hour then use the right arrow to switch to the minutes and again use the up or down arrows to change the minutes
Turn system on with only clock showing Press and hold "A" audio button till hour starts blinking the rest is easy too work out
Posted on Jul 11, 2008
natenash7986
  • 53 Answers
SOURCE: Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Posted on Sep 24, 2008
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
Need engine code for vauxhall corsa b 1.2 16v ecotec engine
Corsa b- x12xe
Corsa c- z12xe
I thought the 16v engine started on the corsa c tho so would assume its the later
Aug 13, 2012 | Cars & Trucks
How to replace indicator switch vauxhall corsa 1.2c
its easy you need to take steering wheel off and don't forget you may need to get code or change the chip from old to new. because some have chip if we don't swap car wont start
Apr 26, 2012 | Vauxhall Astra Cars & Trucks
I shut off my car and turn it back on i need to setup the radio and my settings again it doesnt save ! im missing the orange wire for illumination but my deck still illuminates its the memory thats doesnt...
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
Sep 08, 2011 | Pioneer DEH-3400 CD Player
Vauxhall Corsa engine management light
as this a uk car the easiest way to diagnose the problem is to take it into quickfit for a diagnostic check(cost a little,but infinately easier.)and if you want them to fix any problem you cant handle its already in thier workshop(last time i did this was on an astra estate 1.6 petrol,problem was down to faulty exhaust sensor saved me hours of "fun"cost me £38 total.....)
Jul 21, 2010 | Ford Freestyle Cars & Trucks
Trying to install a new pioneer radio to a 1999 jeep
try walmart they have the wiring harness that you need to install your radio for about 6 dollars
Aug 10, 2009 | Pioneer DEH-1100 CD Player
Automute car kit for Sony Ericsson OEM HCB-300
I am having the exact same problem with my vauxhall corsa and my pioneer deh-6000ub its so annoying it works with the manufacture stereo soon as i connect my pioneer in it doesn't come alive (the HCB-400)
Mar 13, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
Car breaks down after 20 minutes
crankshaft sensor most prob cause - coil pack would normally give misfire symptons as well.
Dec 29, 2008 | Pioneer AVH-P6500DVD Car DVD Player
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Nov 12, 2008 | Pioneer DEH-1600 CD Player
Adaptor for DEH-1600R ?
No other way than use FM-transmitter. There is no RCA-in connectors in unit.
Here is one FM-transmitter.
Oct 10, 2008 | Pioneer DEH-1600 CD Player
Car Audio & Video Logo
102 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
