Question about Epson Stylus CX4800 All-In-One InkJet Printer
Power light is off, red light steadily on..on my monitor it says cancel all printing jobs.turn off your printer and take off the foreign object inside..i dont know how to open it.
  • 495 Answers
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 12, 2009
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
Aug 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. for epson stylus r 290
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on.
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. how to solve this problem?
Nov 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Every time i switch my printer on i get this message: "Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back...
there may be some paper fragments in the roller assembly..one trick..turn off the lights, close the door, and use a pen light to peer into the usually dark and black area..the paper will glow brightly if it is in there..
the print jobs are usually located on the lower right tray, behind a right click on a printer manager icon
Oct 13, 2008 | Office Equipment & Supplies
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
