Question about Gemini PT-1000 II Turntable
Turntable spinning to fast
One of my direct drive turntables is spinning to fast and cant seem to change the speed or stop and start it without having to power off and on, can someone please help! Also is there anywhere i might be able to get a user manual from? Cheers Lee
  • Gemini Master
  • 5,056 Answers
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Posted on May 19, 2013
SOURCE: Nothing happen when pressing the Start/Stop button.
One ov my decks (same Gemini PT-1000 II) had the same problem. Just open it and clean the micro switches underneath the big buttons. It worked fine for me.
Posted on Aug 05, 2008
dunnbiker
  • 8546 Answers
SOURCE: my turntable has stopped spinning when i press
Since it's Direct Drive there's no belt to fall off. There is an electronic brake.
Could your problem have something to do with the Reverse function? Check the L.E.D. Perhaps cycling it will help.
USING THE REVERSE BUTTON:
1. Press the REVERSE (17) button to reverse the rotation of the
PLATTER (2) (the REVERSE LED (17A) will light while in reverse
mode). Press the REVERSE BUTTON a second time to return to
normal play.
http://www.geminidj.com/disc._prod_manuals/TURNTABLES/PT-2100/PT-2100.pdf
Posted on Apr 04, 2009
SOURCE: cant get my turntables turned on and there
if there is a slot for a power cord on the turntables them selves then yes you need the power cords
Posted on Apr 22, 2009
  • 189 Answers
SOURCE: my 33 & 45 speed giving problems
HELLO
I have just posted a cure for this deck, it is to do with the microswitches under the speed select buttons - they need to be replaced. Just repaired mine today - now there are no more problems selecting speeds.
If the speed goes back to 33 when the deck is switched off, this is because 33 is the default.
ALL THE BEST!
Posted on Jul 31, 2009
  • 73 Answers
SOURCE: One of my turntables is spinning out of control,
Sounds like the motor control circuitry has a fault, beyond the effects of maintenance adjustments. Quite often, a transistor and perhaps other active electronic components are used to provide a stable calibrated voltage that drives the platter motor. If one of these components fails, the drive motor can be fed the larger unregulated supply voltage; hence, the out of control platter speed. This can happen to belt drive or direct drive turntables. Not so with the old rim drive units. Unless you have technical experience in this area, you should have a stereo type tech look at it. I'd avoid the high end audiophile type repair services. Shop around for an old school regular tech, and the repair should be relatively inexpensive. FYI, I've seen these hi end shops charge $50 or $60 for a turntable belt that should only cost around $20. If you feel the repair estimate is too much, you can find good used turntables at some stereo stores, or even at some thrift shops for a fraction of replacement cost. Depends on your standards.
Posted on Oct 07, 2010
Runs fast about 78rpm.
You don't say if it's a belt or direct drive turntable. If it's a belt then something might have caused the belt to slip off it's normal position so it runs fast.
Direct drives are more complicated, but it would seem that the voltage control circuit that feeds the motor is applying to much to it and the therefore is faulty.
Mar 04, 2014 | Technics Audio Players & Recorders
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Turntable runs far too fast
Post model number and make of the turntable.
Feb 28, 2013 | Audio Players & Recorders
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
Hitachi Ht-354 direct drive. Why can't speed be adjusted?
Direct Drive turntable's have electronically controlled motors with complicated systems to keep them at the right speed.
My guess is that there could be a power supply issue that feeds one of the motors that is sending a much higher voltage to it. But that's just a guess. You might want to look around for the service manual for it to see how the motor is controlled.
May 01, 2012 | Audio Players & Recorders
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!
are you sure, that your speed selector is on 33.3rpm, not 45?
assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.
Good luck,
Alex.
Jan 11, 2012 | Aiwa PX-E860 Turntable
Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Feb 15, 2010 | Sony PS-LX250H Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
Gemini PT-1000 II Turntable Logo
177 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
