Question about Kenmore Dishwashers
Kenmore 665.13749k600 dishwasher schematic
Certain lites flash,no operation . some kind of error code ?
4 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: what does the error code on a kenmore dishwasher
Hi
To resolve this problem you will have to reset the console. Do this by closing the door and press these buttons in sequence...
* high temp wash
* heated dry
* high temp wash
* heated dry
all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it)
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Posted on Apr 17, 2010
jyackle5
  • 8197 Answers
SOURCE: 2006 kenmore elite dishwasher 665-17263402- the
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Posted on Oct 17, 2010
  • 3247 Answers
SOURCE: Kenmore Dishwasher Mod# 66513753K602 control panel lites
If there is no other problem, that is the dishwasher completed the previous cycle successfully and the only issue is all lights on the panel flashing, it is likely a problem with one of the switches in the panel.
Turn off the power and back on. If no change then get to the control panel. You can refer to this diagram item 1.
Might have to replace it.
Posted on Jun 28, 2011
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Light flahing
will have to repair the circuit board as something is faulty in the board.
it will not be too costly as the lights are flashing and that means only something is short.
thanks.
Sep 21, 2008 | Kenmore 13732 / 13734 / 13739 Dishwasher
Tip
Blinking Clean Light on Kenmore & Whirlpool Dishwashers
on Feb 28, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Quietguard standard. Why is it stuck on lock (the green light under the 'heat dry' button is on)?
This light being on could very well be an error code! Is it blinking a certain number of times, check your user manual or look up the model number you have for error code designations--there can be many--if the unit encounters a problem, it will stop to protect itself from further damage or creating a hazardous condition, and, usually flash an error code or turn on a certain light under a function--you have to look up what that light means to find out where the problem is.
Aug 18, 2015 | Kenmore Dishwashers
I have a kenmore elite dishwasher 577-9 17262402. The clean light is flashing. How do I stop it from flashing to start the dishwasher?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 21, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore dishwasher will not start
May 28, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
May 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore elite keeps flashing red on smart wash button. It won't do anything else.
Feb 18, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite dishwasher Options light up but nothing runs.
Jan 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
