Question about Panasonic PT-60LC14 60" Rear Projection HDTV
Horozontal balck line across the middle of the screen
My TV is showing a 7 inch horozontal balck line across the middle of the screen, it only shows when a DVD is played in a DVD player. Different cables have been used, we have connected the DVD player to different ports, we can play a DVD in the Xbox just fine.
  • pookys_mommy Mar 14, 2009
    Yes, I tried RGB and S cables and the line was still there. I do not have a HDMI cable to try.
    This is also a brand new DVD player, we have used a known good DVD player and the line is still there as well
  • spqr163
    spqr163 May 11, 2010
    did you try the rgb cables, the the s-cable then hdmi if it has one, of the dvd player?
  • 37 Answers
Also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Posted on Mar 15, 2009
Nothing on screen when DVD inputs are plugged into our Aquos.
Check that the input you are plugging the DVD into on the TV is actually selected as the TVs input. Try using a different input and also different input types/cables. Most DVD players will have HDMI and also either component or composite type outputs. Try the different cable type and make sure the TV is looking at the correct input. Do you have sound?
Feb 11, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
When playing a DVD, there are red and blue lines that show up on the screen. At first I thought it was a defective DVD but put another in and it showed up again.
The lines could have been caused by quite a couple of issues one could be a faulty lens from the player or the cables which are used in playing or even the screen. Try using a different screen to watch same DVD's if the problem persists then try replacing the cables for connecting to the screen and after that if it still persists then get an expert to check the lens of thee player.
Hope this solution has been helpful?
Apr 10, 2011 | Bose 3·2·1 II System
I have a Sony Bravia 52 inch HDTV that has a line down the middle of the picture in some shows, particularly when action is panning across a scene. Is this a common problem?
Check with a different CD or a different channel. Sometimes some,
secret codes are displayed to find the pirated CD. Any how check in different program channels. This is not TV problem.
If you have DVD try a similar action movies in CD and play to satisfy!
Aug 21, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Dvd player plays dvd but the screen only shows lines & the audio is fine.
Sounds like your av cables may need to be replaced or the DVD is bad. Check that the cables are in the correct ports coming from the DVD player to your television and that the cablesd have also been placed in the correct postitions.
Good luck
Nov 11, 2009 | Drive Mobile Entertainment MOBILE VIDEO 7...
Only have one horozontal line across mid screen
Horizontal line shows problem in Vertical Deflection area of TV, please check Vertical Output IC and its voltage supply. You didn't mention model and brand name so I gave you general information for that problem.
Aug 22, 2008 | Televison & Video
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Panasonic PT-60LC14 60" Rear Projection HDTV Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
