Question about Gemini PT-1000 II Turntable
Direct drive spinning to fast
One of the turntables is spinning to fast and i cant seem to change the speed or stop and start it without having to switch the power off and on. can someone please help and is there somewhere i can download a user manual? cheers lee
    Problem Solver:
  • 5 Answers
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Posted on Dec 19, 2013
Runs fast about 78rpm.
You don't say if it's a belt or direct drive turntable. If it's a belt then something might have caused the belt to slip off it's normal position so it runs fast.
Direct drives are more complicated, but it would seem that the voltage control circuit that feeds the motor is applying to much to it and the therefore is faulty.
Mar 04, 2014 | Technics Audio Players & Recorders
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
Hitachi Ht-354 direct drive. Why can't speed be adjusted?
Direct Drive turntable's have electronically controlled motors with complicated systems to keep them at the right speed.
My guess is that there could be a power supply issue that feeds one of the motors that is sending a much higher voltage to it. But that's just a guess. You might want to look around for the service manual for it to see how the motor is controlled.
May 01, 2012 | Audio Players & Recorders
The turn table is going round but its playing the record to fast the speed seems wrong
Hello!
are you sure, that your speed selector is on 33.3rpm, not 45?
assume, it's in correct speed settings. do you know, that across the ocean power grid AC frequency is 50hz, in US it's 60hz. Means: ac motor will spin faster, than it should. If you bought this unit abroad, that's where is your problem at. some expensive units have 50/60hz pulleys switch, some not. Especially, if it's DC or direct drive motor. Check your owner's manual for specifications. May be you find an answer. If not, there is a problem with motor's regulator, which is built in(DC motor). Turntable is a belt driven. If you won't find 50/60hz adjustments, take it to repair shop.
Good luck,
Alex.
Jan 11, 2012 | Aiwa PX-E860 Turntable
Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Feb 15, 2010 | Sony PS-LX250H Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
Ion turntable speed problems
Turn the tturntable over, there is a speed control pot on the bottom
Nov 07, 2008 | ION Audio iTTUSB Turntable
Turntable spinning backwards
If it is a direct drive TT then it uses some electronic circuitry to control speed and it sounds like that circuit is having a problem. Possibly the actual driver IC for the TT motor has gone bad. Good luck.
Feb 13, 2007 | Vestax Pdx2000 Direct Drive Turntable...
Gemini PT-1000 II Turntable Logo
101 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
