Canon PIXMA iP4200 InkJet Photo Printer
Problem for Canon PIXMA iP4200 InkJet Photo Printer
Service error 6000
By roogle on Aug 03, 2007
I have a Canon Pixma ip4200 printer which has worked pretty well up until now. I printed 2 pages off and at the end of the second page a service error code 6000 appeared. I emailed their helpdesk and was told that it is a paper feed error and to send it for service to be repaired. It will cost £59.93, so I might as well buy a new one for that price if I can't do it myself! Does anyone have any idea how to solve this?
Many thanks
Comments:
Aug 06, 2007
- Thanks for that. We found out after finally getting the cover off, that something had fallen down the top paper feed and jammed in the cogs. We've managed to resurrect the printer and it seems to print fine now - bloody kids!!
Many thanks for your help, and I'll remember about the sandpaper!
Best Solution
posted on Aug 04, 2007
Helpful)
KOakaKO
Rank: Wiz
Rating: 85%, 206 votes
I can't tell you specifically what you should do to try and repair your printer, but I do have one suggestion, a link to a Service Manual and a probable reason why a service tech wants to charge you so much for a repair.
If you look in the service manual, here is what it says regarding error 6000:
Line feed error [6000]
Solution
(Replacement of listed parts, which are likely to be faulty)
- Timing sensor unit (QM2-2683)
- Timing slit disk film (QC1-6229)
- Feed roller ass'y (QL2-0925)
- Platen unit (QM2-2202)
- Logic board ass'y (QM2-2670)*1
- PAPER FEED MOTOR (QK1-1502)
In other words, somebody looked in the book and quoted you a price to replace all these parts.
One very common problem for printers is that the paper feed rollers develop a slick surface and don't grip the way they are supposed to. If you're experiencing a paper-feed problem, you can try buffing the rubber feed rollers lightly with fine sandpaper to help them grip once again like they should. (I've repaired many printers doing nothing more than this.)
Below is a link to the Service Manual for your printer. Hope this helps.
http://noel.bouvet.free.fr/ip4200/Canon%...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 05, 2009
Very Helpful)
Paean Fey
Rank: Apprentice
Rating: 100%, 2 votes
i have canon pixma ip1200, and I encountered the same problem with yours..SERVICE ERROR 6000, i tried to do a lot of things in my printer, i tried to Turn it on and off but it doesn't fix my problem, then I read that error came from, paper feed and roller..then i tried to pull and roll the soft plastic of the roller at the left side of the printer (if you're facing the printer, make sure the printer is off) then i notice that something's blocking the roller and then i turned the printer on and that's it..it works again, so far i've encountered the problem 2 times and i did the same procedure at the second time i encountered the problem.. I hope this will HELP you..;-)
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Sep 07, 2009
Not Rated)
bakabussa
Rank: Apprentice
Rating: 0%, 0 votes
Solution #2 posted on Mar 05, 2009
Paean Fey
Rank: Apprentice
Rating: 100%, 1 votes wowww...you are genius...elakira aaa..
Was this helpful?
Yes
No
Solution #4
posted on Aug 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
SERVICE ERROR 6000
Popular Solutions for Canon PIXMA iP4200 InkJet
Questions and Unsolved Problems for Canon PIXMA iP4200 InkJet
Do you recommend Canon PIXMA iP4200 InkJet Photo Printer?
Answer
Answer
I have a problem with the paper feeder.The printer worked a minute ago when I printed a thick sheet,... (More)
Answer
I've a iP4200 printer. The waste ink absorber is full & needs to be replaced.
Answer
The middle light keeps flashing and does not stop -(No paper jam) - light blink 3 times the stop... (More)
Answer
The printer is not very old...I am having trouble with the paper feed. ..paper crumples a bit in rt... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
