Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
I GOT A PROBLEM BECAUSE I FORGOT MY PASSWORD IN MY NETGEAR ROUTER..I RESET IT ALREADY YET PASSWORD AS MY PASSWORD CAN'T CONNECT ALSO
  • Carl Navarro
    Carl Navarro May 11, 2010
    What IP address does your computer have? What address are you using to get to the router? Those addresses by default ought to be 192.168.1.2 and 192.168.1.1. If your router really reset, the usaername and password is "admin" and "password" without the quotes as the manual says.
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2/3, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
you might want to consider this for your dlink wifi adapter;
for xp users only;
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Posted on Apr 10, 2009
I have a netgear readyNAS NV+ that i want to reset the password.
Whether you bought a used Netgear router or just forgot your own password, you can reset it and start over.
This is not an unusual problem, so Netgear has made resetting and restarting their routers a simple task
Connect all of your devices.
If your Netgear router is not already connected, it should be plugged in, with one Ethernet cable connecting it to your computer and a second Ethernet cable connecting it to your computer's modem.
Locate the reset button on the rear of your Netgear router.
The reset button is a small inset button and requires a pointed object to reach it.
Use a fine-tipped pen to hold the button down for at least 10 seconds.
The test light should flash during this process.
Open your Internet browser and enter the Netgear router's IP address into the address bar to access the router's information. Generally, Netgear routers use the IP address 192.168.0.1, but the specific IP address will be listed in the router's manual.
Attempt to log in to the router with the default username and password.
The default username is "admin" and the default password is "password."
If the router's username and password were not cleared away, unplug the router and try holding down the reset button.
While you are holding down the reset button, plug the router back in.
Log in to the router using the default "admin" username and "password" as the password.
You can now reset your information, rename your router and enter your own username and password.
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Sep 03, 2013 | NetGear Computers & Internet
Forgot router password
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 24, 2012 | NetGear Computers & Internet
My problem is how to change my password.i already forgot my old password. i used the user name and password at the back of my router and when i log in again, they are not accepting the old password. whar...
http://192.168.0.1
Oct 09, 2011 | NetGear WNR2000 Wireless Router
Forgot username & password for netrouter wgr614v7
How do I log into my router?
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • http://www.routerlogin.net or http://www.routerlogin.com
    • http://192.168.1.1 or http://192.168.0.1
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
This information is extracted from www.netgear.com, for learning purpose only.
Hope this will be useful for your question.
Good luck. Remember to rate my answer please.
Jul 13, 2011 | Computers & Internet
How to manually set up the router from Netgear?
Jun 05, 2011 | NetGear MBR624GU Wireless Router
FORGOT MY PASSWORD WHAT CAN I DO
well here is two links from the manufacturers site dealing with this problem hope this helps and please vote 1 http://kb.netgear.com/app/answers/detail/a_id/12744/kw/forgot%20wireless%20password 2 http://kb.netgear.com/app/answers/detail/a_id/9665 basically hold in reset button then unplug it then it should be reset to factory passwords which are Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
Nov 29, 2010 | NetGear WNR1000 Router
How to set up a password ,i already have everything working, but i had to reset my router because i forgot my password, and now i want to set it up with a new password
To reset the Netgear back to the factory defaults, power up the Netgear and press and hold the pinhole RESET button on the back of the router until the LEDs flash.
You can the now go to the router's configuration URL to login and change the default password and wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Aug 11, 2010 | NetGear WGR614 Wireless Router
I have a netgear router WGR614v9 . I forgot its password. I can not connect any computer to internet. How do i reset the password?
There should be a reset button at the back of your Netgear router. Press it for 10-30 seconds and that should reset it back to factory settings.
Cheers!
Angel
Jul 08, 2010 | NetGear WGR614 Wireless Router
Finding netgear password
Usually you have a reset button on your router. Maybe you need to insert a paperclip or something like that into a hole to get to reset button, and hold it for a few seconds.Once reset is done your router will reboot and all your settings will be erased, than you have to configure it again. first connect it to your PC with a network cable, than open a browser and type your routers IP into address bar and hit enter. A window will pop-up with a username and password.
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
Jan 15, 2010 | NetGear DG834G Router
Hi I just purchased a HP laptop equiped with WLAN wireless. However it will not allow me to add my wireless connection in order to access the internet. I cannot remember my password to the netgear.
I DON'T HAVE NO IDEA HOW MANY PC IS CONNECT TO THIS NETGEAR ROUTER. IF YOU FORGOT YOUR PASSWORD OR SOMEONE CHANGE THE PASSWORD. YOU MAY RESET THE ROUTER TO FACTORY SETTING BY AT THE BACK OF THE ROUTER THIS A LITTLE HOLE A PAPER CLIP IS THE PERPECT TOOLS TO RESET IT. THE DEFAULT ID USER IS ADMIN AND THE PASSWORD IS PASSWORD. HOPE THAT THIS INFO WILL HELP YOU SOLVE THE FORGOT PASSWORD AND TO CONNECT TO WIRELESS PROBLEM.
HH
Aug 14, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
201 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
