Question about Olympus Pearlcorder T1000 Desktop Cassette Transcriber / Recorder
Where to purchase tape recorder motor rubberband
The black rubber band on motor and pulley has melted off,where can you find the thin black rubber band?
  • 145 Answers
You can order from www.dictationmall.com at 866-321-9780
Posted on Apr 22, 2013
My cassette player does not work on my SONY CFD-50 boom box. The drive motor runs but does not forward or re-wind the tape. If the drive belt is off how do I replace it ?
If you can get the part from an electronics supply (we have a place here in my medium sized Canadian city). Once you obtain the part it just takes patience and a natural ability at puzzles to be able to replace it. Perhaps you should remove the old one first to be able to size it.
Oct 16, 2013 | GPX BCD2805 Radio/Cassette/CD Boombox
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
The unit is eating up the tape!
Generally speaking, there are two reasons this happens.
[1] tape recorders have to move tape past the record/playback heads at a highly consistent and accurate rate of speed. What makes this possible is a rubber "pinch" or pressure roller and a spinning metal spindle. Tape is routed between the roller and the spindle, and when the recorder is in RECORD or PLAY mode, the roller presses the tape against the spinning spindle, causing the tape to move from the feed reel to the takeup reel. When the pinch roller and/or the spindle become coated with oxide particles shed from old tapes, they get sticky and the thin tape will begin wrapping around one or the other. THE SOLUTION is to get some cotton swabs and rubbing alcohol and clean the oxide (brown from cheap tapes and dark gray from better tapes) from both of these parts.
[2] many tape recorders use rubber belts and pulleys to turn the feed reel and the takeup reel. If the tiny rubber belt that makes the take-up reel turn is stretched, it will not wind moving tape fast enough, which causes tape to bunch up. If this is the problem (you will not be able to see the belts without removing the recorder's outer case), then you might as well junk the recorder.
If you see that the part of the rubber drive roller that contacts the moving tape has a ring of brown or gray coating on it, you
Feb 19, 2010 | Sony TCS-580V Handheld Cassette Voice...
Aiwa lx 70 turntable needle arm
This is not a solution but it is information. I just got one of these turntables and the platter rotates but the tonearm does not move. I took it apart after downloading the service manual and found that there are two small thin rubber belts that due to age have fallen apart and "melt" when you try to pick up the pieces. One controlled the sideways movement of the tonearm "carriage", the other controlled the lifting and lowering of the tonearm. The replacements are expensive (I think around $18 each) and in trying to pop loose a worm gear with a pulley buit into it, so that I could try a cheap rubber band out just to see if the unit would work with new bands, I broke the stiff plastic "retainer" that by its shape was designed to be pushed out of the way a bit to allow the worm gear to be removed. The service manual, by the way, had all sorts of information about how to make fine adjustments, but said nothing at all about how to replace the belts. Unless removed there was no way to put the replacement band in place over the gear/pulley combination because there was no exposed end to slip a complete band over. So I think it was a bad design, made worse by the aging of the components that made the bands melt and the plastic "keeper" brittle so that instead of flexing out the way it broke. So I'm going to recycle the components. I did not find any reviews to tell me how good a component unit this was, so before you hire a pro to try to fix this unit you need to figure out if it will be worth it to you in the long run. Anyway, good luck.
Feb 15, 2010 | Aiwa Audio Players & Recorders
When I press play, my tape player eats the tape.
that means that the uptake wheel is not turning. typically this is caused by a rubber band that is insde the transport mechanism that connects the motor to the wheel.
if you are comfortable taking the device apart, you will need to find the right band and just pop it on.
Mar 16, 2009 | Sony Boom Box With CD Player & Cassette...
Tape recorder belt
Use a durable rubber band. It works for a while!
Sudhir
Oct 24, 2008 | Audio Players & Recorders
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
Olympus Pearlcorder T1000 Desktop Cassette Transcriber / Recorder Logo
71 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
