Question about Proscan PLCD3992A 39 in. LCD HDTV
What size base screws - Proscan PLCD3992A 39 in. LCD HDTV
How to find replacement parts for my television base
For 22" or 19" Emerson TV base 3 screws (M4 x 12)
Emerson LC190EM2 User Manual Supplied Accessories Symbols Used In This...
this size may differ for your TV based on its size and quantity may differ based on the design / model of your TV.
could have helped if you mentioned the model number as well.
May 26, 2016 | Emerson Televison & Video
Standard light bulb base to large base adapter.
go to an electrical wholeshop shop that caters for the trade and they will have it if such a thing is available
hard ware shops may have but as it is a specialized fitting , I am thinking only the wholesale out lets will carry it
May 11, 2016 | Cars & Trucks
What size screws to use for the issue described below?
Sometimes the base screws, on brand new tvs, come in the 4 holes in back for mounting the tv on the wall.
Dec 08, 2015 | Toshiba 40FT1U LCD TV
I have lost the screws to my 50" soniq tv base. What size screws do I need
Buy an inexpensive screw hole size template (used for inserting screws of unknown size into it, and reading what size hole it fits into, and then going to buy that screw) at Home Depot (HD) or Loews. If there is room to lay the template over one of the holes, you can eyeball which hole on the template is about the same diameter of the screw hole on the base. Then go to the store and look for that size screw (machine screw Vs wood screw), and purchase one of each of three sizes (the one that appears to be the one, and one that is the next size down, and one that is one size larger. Then see which one fits in the base (this will be a bit of trial an error). This should work until the right size is identified.
Sep 19, 2014 | Televison & Video
Size of screws for sanyo 55 inch LCD to mount base to tv
After repeated trips to the hardware store and more calls to Sanyo and conversations with supervisors...depending on the year of the TV....2011 requires M5x16. The next year model requires the same size that bolt to the back of the TV. I had to elevate my request for the size of the base screw of the 2011 model all the way to engineering before I got the answer. They changed the configuration in the 2012 and later models.
Jan 02, 2014 | Sanyo Dp55441 TV
Base plate screw size Toshiba 50"
To know about the screw size, you have to download its repair manual by internet. It has disassembly details of the set, and have details about all screws and other stand parts. If you wish to get some details about these, check the site linked here. It has disassembly procedure illustrated to many brand TVs. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 18, 2013 | Televison & Video
Replacemaent screws that hold phonelic plate to base
take old screw to hardware store find a nut that fits then calculate the length of screw need in the same thread and size (safest way because even the same mfg will vary on bed screws and this is fool proof
Dec 07, 2008 | Freud FT2000E 3 Router
Proscan PLCD3992A 39 in. LCD HDTV Logo
23 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
