Question about SanDisk Sansa e260 MP3 Player
Display says not enough space for music database
I overfilled my sansa sandisk mp3 player and I cannot get to the music files to delete songs. How do I access them from my computer. If I click on any of the folders in the sandisk they are empty. I just need to get to the files and delete them so it is not full.
    New Friend:
  • 40 Answers
Here is some useful information I found on the web - I used it to upgrade the firmware on my daughter's Sansa mp3 player:
Try the Sansa Recovery Tool
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 12, 2009
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
When i turn my sansa fuze on it says "not enough space for music db please free 90mb"and turns back off..how am i able to get it to wrk again?
When the player is rearranging playlists of the music database, it is possible that there's not enough memory left in the player to finish the task.
Connect the player with your computer to delete some files, at least 90 MB, off the Fuze to make it work again.
When not having a backup of the songs, save them onto the computer first.
Here's the support site for Sandisk Sansa Fuze:
http://kb.sandisk.com/app/answers/detail/a_id/3249/session/L3NpZC93dDhKSlRaag%3D%3D/sno/0
Directly to the Sansa Fuze user manual:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Need more help ? Just add a comment.
Apr 20, 2010 | SanDisk Sansa Fuze MP3 Player
After changing out the battery, i turned it on and
The database seems to be overloaded while rebuilding the files info and playlists.
See the answer for "Not enough space for MusicDB" :
http://kb.sandisk.com/app/answers/detail/a_id/848
For the c100 series connect the player to the computer how to delete files see:
http://kb.sandisk.com/app/answers/detail/a_id/41
When linked to the computer there are 2 different connection modes possible:
  • MSC mode seeing the player as a removable disk using Windows Explorer.
  • MTP mode seeing the Sansa player as a Media device using software like Windows Media Player.
For "cleaning up" your database check both lists. How to switch to MSC / MTP mode:
http://kb.sandisk.com/app/answers/detail/a_id/447
Manual for Sansa c100 series:
http://mp3support.sandisk.com/downloads/um/c100-um.pdf
Sep 28, 2009 | SanDisk Sansa c140 MP3 Player
Sansa e260 has no space left to write the database info. Vista and also Windows Media Player don't ''see'' any files. I can listen to all the music on the MP3 but I want to delete some and add others.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Start over put new songs on it
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
PLEASE HELP I CAN"T LIVE WITH OUT MY SANSA
"Please free 6MB for music DB" means that there is not enough MEMORY for the MUSIC DataBase. Therefore, you cannot see the music on your device.
To resolve this, you need to delete music until your device is less than 6MB of being full.
Generally 10 to 15 songs should do the trick.
Best of Luck,
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
80 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
