Question about Ricoh AficioSP C222DN Laser Printer
How do I reset printer after loading toner? - Ricoh AficioSP C222DN Laser Printer
  • 58 Answers
There's no need to reset because the machine will detect the new toner automatically
Posted on Apr 22, 2013
My printer will not load the toner. Its said the toner was low, so I replaced it with new toner and now it will not load. HELP!!!
you had to go into sp mode....then go to drum function.....tap the
execute .....the pcu will automatic mix the new toner and will reset the teh copier/printer sensor.....now dear Jocelyn,do you know how to enter the sp mode........
Sep 12, 2013 | Ricoh Aficio AP3800C Laser Printer
Gestetner dsm730 error code sc590
SC 590 - Toner collection motor error.Possible causes:
- toner collection motor defective
- too much load on the drive mechanism
- poor toner collection motor connector connection
- toner collection motor sensor defective.
Reset procedure:
1. Turn OFF/ON the power switch.
If the trouble don t reseting press the Clear (yellow) key press 107 press and hold last more 4 seconds the Stop/clear(red) key,enter inSP mode,then turn the main power switch OFF/ON.
Feb 04, 2013 | Gestetner DSm730 Black and White Copier
How to reset the printer --appears to be no paper jam and appears to have toner but red light keeps flashing
the toner is not inserted properly and is not detected by the system .pls try to re insert the toner this time make sure that it is inserted properly and the motor winds it up then closer the cover and locks it.this will till the system that toner is loaded and is ready to print..
Jun 06, 2012 | Kyocera FS-920 Laser Printer
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
The toner life ended and then we got a refill. Earlier on refill, It was working fine, But this time it still says , TONER life end, replace toner. We tried loading 2 different refilled toners and cleaned...
we can refil toner many times but we should reset cartage, while we refiling toner to open cartage we should sides white rings middle plastick flate white plate make adownof cartage it is first methode. when we put reffiling cartage put on printer and do on at that time we push cartage right side pointo re set. look on www.brother.com
Nov 05, 2009 | Brother MFC-7820N Printer
Toner light is on and I have a new cartridge in it
The toner sensor where the cartridge is loaded is fouled or you refilled this cartridge and the printer does not reconise the toner inside and thinks its empty ether or sensor or refilled cartridge the printer thiks there is no toner.
1. Did you refill the toner?
2. Brand new cartridge > take it back to the retailer if that does not work the printer will need repair.
Please do leave positive feedback and ratings for your free answer today!!
Oct 20, 2009 | Brother HL-2040 Laser Printer
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Samsung scx-4300 toner exhausted
samsung scx-4300 error message "toner exhausted" how to reset printer
Apr 11, 2009 | Office Equipment & Supplies
Toner empty error while toner is not empty, cannot print any document, system data can be print through the printer
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
Dec 04, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Ricoh AficioSP C222DN Laser Printer Logo
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
