Question about Ricoh AficioSP C222DN Laser Printer
How do I reset unit after I loaded toner. - Ricoh AficioSP C222DN Laser Printer
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
I have a Ricoh Aficio 1013F that has a about 65000 copy count. I replaced the drum/imaging unit a few months ago. recently, we stupidly let the machine run a week or so while it was calling for a toner...
I think you will have to reset it ..and the procedure to follow is this..
take it slow and be sure it is the correct one ..If it seam not to work try again ..
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Aug 13, 2011 | Ricoh Aficio 1013F Copier
New toner loaded but shows load toner mssage Toner execution failed
here are some tips for you to check on:
1/ check your copy counter,if it is already 120,000 copies and you have not yet replace the OPC unit then you should.........
2/ the toner holder bottle unit is not working properly,need to be checked and cleaned...some time the safety cap is not open for toner to be feeded to the OPC unit.........
3/be sure that you follow the instruction of how to install the toner bottle,
4/if the problem is still there??? your toner motor needs to be replaced......
enjoy the experence!!!!!!!!!!
Nov 03, 2010 | Ricoh Aficio MP 1600L Black and White...
We have a Ricoh Aficio 350 copier that is quite old but has worked well through the years until now. It keeps displaying ADD TONER and runnng after we have already put in a new cartridge. Under add toner,...
take the toner supply unit out. toner supply unit is one where toner bottle fits and vacummed clean the unit. the toner unit is blocked. i am a Ricoh technician.
Sep 23, 2010 | Office Equipment & Supplies
My Ricoh CL7000 keeps asking to replace the yellow toner, which I have done and it goes through the motions of loading the toner then the error message comes back again - asking to replace the yellow...
The toner cartridges for the CL7000 have microchips embedded in them, so the machine knows if it's not a new cartridge. Was the cartridge you put in brand new? (And was it a genuine Ricoh cartridge?)
On those printers, the toner is pumped into a developer system and mixed with the developer before making the image. In the developer unit, the density is checked, so if it's not seeing the right mix there, one of three common problems could be causing this.
The more likely solution is to replace the yellow developer unit, which comes as a whole unit and just slides right in. That will reset your density levels and should correct the "load toner" error.
There is a spring and cushion mechanism that the toner cartridge sits on -- this mechanism can easily be popped out of place and cause problems loading the toner. Take out the yellow toner as well as one of the other colors, and see if the little black circular piece is sitting the same way for both colors. If not, just pop it back into place, using the second color as a guide.
The other likely possibility is that the yellow toner supply tube is clogged, but that doesn't happen very often. To test if it's clogged, take out the yellow toner cartridge and the yellow developer unit and turn the copier off. Use a vacuum to provide suction at one end of the tube (the toner end will be easier) and put your finger on the other end (the developer end) and see if you feel the vacuum's suction. If not, there is probably a clog somewhere in the line.
If there is no clog and you can feel the suction, you may have a bad toner supply motor.
As a side note, if you find the problem and fix it, you might still have to put a new yellow toner cartridge in to get the machine running because it will think the cartridge you already tried is empty.
Hope that helps!
Jun 11, 2010 | Ricoh Aficio 1035 Copier
I changed the drum unit on my c5500 printer and didn't realize that I needed to replace the toner at the same time. I just replaced that toner about a month ago and now it's saying it's empty - which I...
Before you replace a drum unit, you should (with the top toner cartridge still in place) turn the unit upside down and gently shake the toner that is in the drum unit back into the toner cartridge. When you install toner on these printers, most of the toner falls into the drum unit. The only way you can "reset" the printer is to add more toner, because there is almost no toner in that new drum.
Oct 20, 2009 | OKI C5500n Printer
Toner not reseting. i installed 2 new toners Cyan and Magenta and still says toner out. i reset the unit, and from the browser. unit is Aficio sp c420dn
Check to see if anything is broken around where the toner fits into the machine I recently had a customer break the piece that holds the toner in place. The machine symptom was that the toner did not lock into place like the other ones did.. GOOD LUCK
May 02, 2009 | Office Equipment & Supplies
Will not add toner
Reinsert cartridge and restart it by unplugging or powering off
It should refresh the memory
Good Luck
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
Ricoh aficio 3025 copies out of alignment
Check the paper size dials (green dials) of the paper trays that are set to match the orientation of the paper loaded in the tray.
On the touch panel display, select Auto paper select icon and retry.
If the dials are correct and the problem still there, please then try to print the counter printout from the User tools (yellow) button or send a print from your computer.
If still with the copies being cut off, please check for toner spillage between the toner unit and Photoconductor unit.
Open the front cover, pull out these units and clean toner spill.
Clean also the laser shield glass. There is a small cover below the toner supply unit, unscrew 1 screw. Pull out the small glass very careful and straight ahead, pay attention not to break it.
Retry copying and printing.
Good luck and please rate me, thanks.
Jan 21, 2009 | Ricoh Aficio 3025P Black and White Copier
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh AficioSP C222DN Laser Printer Logo
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
