Question about Extreme Networks BlackDiamond 8800 (41211) Networking Switch
Extreme switch gets rebooted after 497 days [bug]
Hi:
You guys probably are already aware of the fact that Extreme switches [Image: 11.6.2.9] gets rebooted after 497 days of uptime. Probably a get around for this problem is to upgrade the image. Is there any other solution [for example: manually change the uptime/boot-time so that it doesnt reach 497?] or any other way around to this problem without reboot?
Is there any way I could use vi editor to manually edit the boot time / up time?
Thanks
Shafiq
2 Suggested Answers
SOURCE: Failure to boot an Extreme Networks 8808
It sounds like...am afraid... the switch may may be developing multiple sclerosis on its circuitry or the processor is losing it. have it checkd.
Posted on Feb 18, 2008
Keeps saying card protected when I inset the SD card
Hi Scott - There is a TINY little "slide switch" on the edge of an SD card that is quite easy to accidentally move. It's purpose is to keep important stuff from being accidentally erased. If you look in the image below, just to the left of the word "Extreme" you'll see the slide lock - it's small, in the "notch" to the left of Extreme. You'll also see that the word "Lock" is written vertically and points down (in this case) to indicate which way is locked. This disk is unlocked. Best wishes.
Jul 09, 2015 | Cameras
Somehow we locked our Sandisk Extreme SD HC 4gb card. And now when we put it in the camera, it says card locked. Can anybody help how to unlock it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 03, 2010 | SanDisk Extreme III 4GB Secure Digital...
How do i set up WingMan Extreme
Hi Cat,
You will need to install LGS ( Logitech Gaming Software ) to configurate this hardware, you can find it here:
http://www.logitech.com/en-us/486/2964?WT.z_sp=Image
Thanks and have a nice day
J -
Apr 04, 2010 | Logitech WingMan Extreme Digital 3D...
Hi ! I suggest you to install the software including drivers + profiler here: http://www.logitech.com/en-us/486/3361?WT.z_sp=Image
Then you can download pre-defined profile for your game here: http://www.wingmanteam.com/profiles/profiles_users.htm
Thanks and have a nice day ! J -
Apr 04, 2010 | Logitech Wingman Extreme 3D Pro Twist...
DHCP problems for wired devices on my network
It sure sounds like the switch is not passing the DCHPDISCOVER packets through to the Apple Extreme.
Is the switch a NetGear Prosafe switch, or a GS608, or a different model?
If it's a managed switch (e.g. ProSafe) then you can connect to the switch's management UI and confirm that the default uplink port is set up for the port that connects to the Apple Extreme, and that it's set to forward DHCPDISCOVER packets to that port
If it's an unmanaged switch like the GS608, then it shouldn't matter which port you connect, but if your model has one port labeled "uplink" then you should be sure to use that port to connect to tha Apple Extreme.
One last thought -- have you replaced the cable that you're using between the switch and the Apple Extreme? You could test the network by first connecting your computer to the Extreme so it gets a valid lease, then unplug it and hook up the full network (computer -> switch -> Extreme) and see if you can still ping the router.
That's a bunch of thoughts, but may not be a solution yet. If these don't address the problem, post back with the model number of your Switch, and I'll go more in-depth.
Feb 12, 2010 | Apple Computers & Internet
Need to hook my airport extreme to a netgear switch and isnt working
Go to System Preferenced/Network and configure your new Airport Extreme card. Download and install the Airport Extreme Enabler from Apple in order to use the card in 802.11n mode. Reboot you Mac.
Oct 10, 2008 | Computers & Internet
Asus Striker II Formula CPU INIT
u motherboard stop of working is fault get another one from a it very professional
Sep 01, 2008 | ASUS Striker Extreme Motherboard
Nov 06, 2007 | Extreme Networks (45210) Networking Switch
2 cpu's one keyboard (adb)
Yes and no. The good thing is this will work the bad thing is the possible droping of the driver connection which rarely happens, but it is a possibility. Also if the cables use mechanical switching there are galvanic issues that may occur (and opto-isolated switch is better). However this will work. This the basic functionality of the KVM switch.
Mar 05, 2006 | Addlogix (MD4-103) Networking Switch
Computers & Internet Logo
434 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
