Question about Honda Garden
1800 psi honda pressure washer tune-up
Model 01195-0 Type 3600CP Serial #4783594 2.0 gpm 1800 psi
  • 7 Answers
SOURCE: oil leak under the engine
If it is a vertical shaft engine then it is most likely the crankshaft seal. That requires removing the engine from the frame and removing the pump from the motor to replace the seal. If it is a horizontal shaft engine then it could be either the shaft seal or the side cover gasket. Both require removal of the pump.
Posted on May 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
eugbug
  • 479 Answers
SOURCE: hi there, i need to
See this link on how to change oil and recommended oil types:
http://www.briggsandstratton.com/engines/support/maintenance-how-to/Push%20Mower%20Engines/How%20to%20Change%20Oil/
Posted on May 10, 2011
How much oil and gas mixture to use in 1800 psi 2.2 gpm washer where do i put in the oil
it is a 4 stroke motor so it just runs on neat unleaded fuel.
oil is in the engine and this should be 30w oil
Jun 18, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
Water is leaking from the front seals,of a model 330m,cant find a parts diagram to describe info on seals so i can order.
See this link
Look to the bottom of the page and click on your model, let me know what parts you need, I usually have them in stock, justin@wmpcs.com
Nov 11, 2010 | Karcher Pressure Washer 1800 PSI 15 GPM...
I have a northstar pressure washer 2000pw serial #03005610 item #157754b someone has took carb off and u was wonderin if u could give me a blowup of how the linkages and springs go ?
You will find your information by looking for model number and code of engine. Look on the fan cover, valve cover engine block or tag directly on the engine itself. Example would be Honda model gx340 from starter of engine. Then check google or mfg. web site for manual showing governor linkage. Norhstar uses several brands of engines. Good luck
Sep 08, 2010 | Northstar Pressure Washer Trigger Spray...
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
May 27, 2010 | Honda Pressure Washer PSI 3000
Troy bilt pressure washer will not build or reach high pressure
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
118 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
