Question about Air Tools & Compressors
Porter Cable - PT501 Impact Wrench Torque selector leaking air
When the air line is hooked up to my impact wrench air leaks out the bottom of the handle. I believe the seal to the torque selector is bad but I do not know how to remove the selector to try and replace the seal.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Beneath the rubber grip there is a roll pin that needs to be punched through the housing to remove the regulator assembly.
you can find a parts list a www.servicenet.dewalt.com
it will shoe the location for the roll pin that retains the regulator assembly
Posted on Apr 28, 2013
SOURCE: Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Posted on Jun 20, 2010
brainyass
  • 242 Answers
SOURCE: Impact wrrench disassembly
Check to see if #27 is holding it in.
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Posted on Apr 25, 2009
  • 37 Answers
SOURCE: 1/2 air impact wrench will not turn socket.
Make sure the fitting are tight on the hose and gun. Also make sure that the switch for forward/reverse is solidly in one position, if it is not it will cause what you described.
Posted on Jul 13, 2009
john631068
  • 172 Answers
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Posted on Nov 17, 2009
Air leak on my IR231 A
It should just be the valve o-ring that is letting air bypass. Its located under your air inlet bushing. If you take out the bushing you will see a spring and a valve. The valve has a o-ring on it so just replace that and it should fix your problem.
Jun 30, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
I have just recieved a porter cable impact wrench,how do i connect the air hose? it has a plug inside a larger nut where the connection for the air hose is,how do i get this out? i checked the instructions...
This plug is usually just a shipping plug to keep trash out. Remove it and install a male quick connect. Put some teflon tape or paste on the threads before installing. Then your end of your air hose should have a female quick connect to plug up to the impact.
Jan 13, 2011 | Porter Cable Tools & Hardware - Others
My pt501 Porter Cable air impact wrench won't turn off
Your throttle valve seal is bad or your trigger pin is stuck. Go to ereplacementparts.com and type in your model# this will give you a detail of the parts broken down.
Dec 03, 2010 | Porter Cable Cable 1/2" Impact Wrench...
Hi, The socket adapter spins before i engage trigger
The seal is bad inside leaking air pressure to the gun without squeezing the triger. Get a reseal kit from Sears
Jan 22, 2010 | Craftsman Tools 1/2" Air Impact Wrench...
Oil leaking from nose section of Porter Cable impact wrench
A little oil is normal...actually it's a special grease.
Apr 05, 2009 | Hammering
Wrench Support
An impact wrench also requires a few special accessories. An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
Aug 27, 2008 | Impact 3/4" Dr. Heavy - Duty Air Wrench
Wrench Troubleshooting
In line oiler Lubrication is critical to extending the life of your valuable air impact wrench and increase productivity. An air tool that has not been properly lubricated will result in low power output. The usual culprit is a dry motor starving for some oil. Your impact wrench is an expensive investment and you must take the time to properly lubricate it. The easiest and quickest way to make surein line oiler it is constantly lubricated is to install an in line oil lubricator. One of these will insure your air tools are receiving oil every time they are used. In line lubricators attach right into the air hose and you fill them with the correct lubricating oil. (see your manufacturer's specs.). You should also do routine external lubrication through the hammer case grease fitting. A well lubricated air impact wrench will deliver more torque, last longer, run quieter and increase productivity. Don't forget to add an in line oiler to your next impact wrench or air tool. It will pay for itself several times over.
Aug 27, 2008 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Wrench Maintenance
Aug 27, 2008 | Campbell Hausfeld Maxus 3/4" Impact Wrench
Wrench question
Aug 27, 2008 | Porter Cable Cable Factory - Reconditioned...
Air Tools & Compressors Logo
140 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
